TCL TIMERS
Leonardo Santana
I,m using this TCL its-CISCO.2.0.3.0.tcl, and i wanna to decrease the interdigit timeout, and the timeout to transfers the call to the operator.
Can somebody help me?
Leonardo Santana
*** Rate All Helpful Responses***
Here is how i might try
a) To set it as a constant inside the script
proc init { } {
    global param1
    set param1(interruptPrompt) true
    set param1(abortKey) *
    set param1(terminationKey) #
   set param1(initialDigitTimeout) 3
    set param1(interDigitTimeout) 4
b) If you want to change it from CLI
In the CLI: param initial-Digit-Timeout x
                        param inter-Digit-Timeout y
proc init_ConfigVars { } {
     global param1
if [infotag get cfg_avpair_exists initial-Digit-Timeout] {
        set param1(initialDigitTimeout) [string trim [infotag get cfg_avpair initial-Digit-Timeout]]
    } else {
if [infotag get cfg_avpair_exists inter-Digit-Timeout] {
        set param1(interDigitTimeout) [string trim [infotag get cfg_avpair inter-Digit-Timeout]]
    } else {
7 Replies 7
dsobrinho
Level 10
Level 10
As I understood your last post, you need reduce the time to awaiting  a transfer to operator.
Something like:
proc init { } {
    global param
    set param(interruptPrompt) true
    set param(abortKey) *
    set param(terminationKey) #
    set param(maxDigits) 1
    set param(initialDigitTimeout) 3
    set param(interDigitTimeout) 4
I have the same problem. with this TCL.
Does anybody Knows something like that?
Best regards
Daniel
Daniel Sobrinho
proc init { } {
    global param1
     global param1
    } else {
    } else {
Hi all,
Anybody show me what are difference between initialDigitTimeout and interDigitTimeout?
param(initialDigitTimeout)  —  Initial digit timeout value in seconds. The default is 10.
param(interDigitTimeout)  —  Interdigit timeout value in seconds. The default is 10. Time Allowed between Dialed digits.
Raghavendra
Thanks for Raghavendra
I want to clarify more with an example. I make incoming call and hear welcome-menu with some options:
- Press 0 for operator
- Press 2 for sale team
-Press the extension number you know (example: 2000)
Call flow:
Welcom-menu play --> end(1)--> press 2 (2)---> press 0 (3)--> press 0 (4)--> Press 0 (5)
Allowed maximum duration from (1) to (2)  is InitialDigitTimeout.
Allowed maximum duration (2) to (3) (or from (3) to (4)) is interDigitTimeout
Am I correct?
Thuc
InitialDigitTimeout  --  intial digit  ie., first digit to be dialed.
interDigitTimeout  ---  Time Allowed between Dialed digits.
Raghavendra
ok, thank you Raghavendra
Thuc
