Web Dialer SSO
MMstre
Level 5
Level 5
I am working to integrate web dialer into an environment using SOAP. We currently use SAML ADFS for internal applicatins.  I am trying to figure out how to capture the taken that is needed, to pass to CUCM, for SSO to work with CUCM. CUCM is already a trusted service, so it should work when the taken is provided.  My question is how to get the token to send to CUCM?
Any direction would be greatly appreciated
dstaudt
See this tutorial for info on application CUCM SSO interactions: https://developer.cisco.com/site/sso/
Note, WebDialer also supports 'proxy user' authentication, where you can place calls on behalf of anonymous users (or users otherwise already authenticated by your app) using a designed CUCM application user credential set: https://developer.cisco.com/site/webdialer/webdialer/authentication/
