Need assistance with pass through normalization script
ferguson.michael
Frequent Visitor
Frequent Visitor
This is my normalization script.  We are trying to pass the X-ECKOH-CALLID through call manager from the inbound Invite to the outbound invite
M = {}
M.allowHeaders = {"X-ECKOH-CALLID"}
function M.inbound_INVITE(msg)
  local eckohcallid = msg:getHeader("X-ECKOH-CALLID")
  if eckohcallid
  then
    pt = msg:getPassThrough()
    pt:addHeader("X-ECKOH-CALLID", eckohcallid)
  end
end
return M
This is the inbound Invite that has the header
21775952.000 |11:53:03.170 |SdlSig   |DbObjectCacheTimer                     |initialized                    |Db(2,100,213,1)                  |SdlTimerService(2,100,3,1)       |2,100,150,1.1^*^*                        |[T:H-H:0,N:0,L:0,V:0,Z:0,D:0]  AppCorr: 0
21775953.000 |11:53:04.188 |SdlSig   |DbObjectCacheTimer                     |initialized                    |Db(2,100,213,1)                  |SdlTimerService(2,100,3,1)       |2,100,150,1.1^*^*                        |[T:H-H:0,N:0,L:0,V:0,Z:0,D:0]  AppCorr: 0
21775954.000 |11:53:04.439 |SdlSig   |SIPTimer                               |wait                           |SIPHandler(2,100,82,1)           |SdlTimerService(2,100,3,1)       |2,100,10,1.1897352^10.246.180.99^*       |[T:H-H:0,N:0,L:0,V:0,Z:0,D:0]  TimerType=SIP_TIMER_REMOVE_TRANSACTION value=32000 numRetries=0
21775954.001 |11:53:04.439 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/wait_SIPTimer: TimerExpired type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0
21775954.002 |11:53:04.439 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: timerContext=0xdddd700 type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0
21775954.003 |11:53:04.439 |AppInfo  |//SIP/Stack/Info/0x0xdddc720/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be
21775954.004 |11:53:04.439 |AppInfo  |//SIP/Stack/Transport/0x0/sipConnectionManagerUnregisterCtxtInCon: gConnTab=0xe118990, addr=10.246.180.99, port=5060, unregistering context=
21775954.005 |11:53:04.439 |AppInfo  |//SIP/Stack/Transport/0x0xdddc720/sipSPITransportContextCleanup: Could not purge context gcb=0xdddc720 from the connection; gcb
21775954.006 |11:53:04.439 |AppInfo  |//SIP/Stack/Info/0x0xdddc720/sipSPIUfreeOneCCB: Freeing ccb dddc720
21775955.000 |11:53:04.830 |SdlSig   |SdlDataInd                             |wait                           |SIPUdp(2,100,73,1)               |SdlUDPConnection(2,100,10,1)     |2,100,10,1.1897368^10.246.180.52^*       |*TraceFlagOverrode
21775955.001 |11:53:04.830 |AppInfo  |//SIP/Stack/Error/0x0/httpish_cache_header_val: DROPPING unregistered header X-Wireless-Orig: yes
21775955.002 |11:53:04.830 |AppInfo  |//SIP/Stack/Error/0x0/httpish_cache_header_val: DROPPING unregistered header Cisco-Gucid: 50C464D001E9C0419FE8000000A63056
21775955.003 |11:53:04.830 |AppInfo  |//SIP/Stack/Error/0x0/httpish_cache_header_val: DROPPING unregistered header App-Info: <10.246.178.174:7000:7443>
21775955.004 |11:53:04.830 |AppInfo  |//SIP/SIPUdp/wait_SdlDataInd: Incoming SIP UDP message size 1469 from 10.246.180.52:[5060]:
[3794706,NET]
INVITE sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.10.10.10:5060;branch=z9hG4bKsik9qi0060bh9vp8tkj0.2
Max-Forwards: 65
To: <sip:[email protected];transport=udp>
From: 9131111111 <sip:[email protected]:5060>;tag=SDrk3ba01-dsb4c66d21
Call-ID: SDrk3ba01-f8a9dde999d4787215d566496d0eb711-agt5rg1050
CSeq: 1 INVITE
Content-Length: 252
Contact: <sip:[email protected]:5060;transport=udp>
Expires: 18
User-Agent: CVP 11.6 (1) ES-7 Build-81
Allow: INVITE,ACK,CANCEL,BYE,REGISTER,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,OPTIONS,MESSAGE,PUBLISH
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
P-Preferred-Identity: <sip:[email protected]:5060>
X-ECKOH-CALLID: SD3tk3c01-2c5e778c4fabf5817c86c2587bef2e91-v300g00N
Session-Expires: 1800
Min-SE: 90
Content-Disposition: session; handling=required
Referred-By: <sip:[email protected]:5060>
Cisco-Guid: 1355048144-0032096321-2682781696-0010891350
Supported: precondition
Supported: replaces
davidn#
Hi Michael,
Your script looks ok to me. You should see the X-ECKOH-CALLID header in the outbound message. If not, you can open a DevNet support ticket and provide appropriate logs so we can investigate.
David
