I'm trying to determine how to track if a phone deregisters from CUCM 11.X. What the alert or event might be? Is there a trigger that is sent that can be captured? Thanks in advance
I have a problem wtih incomignn call when we are using tcl on dial-peer. We have one example did that is unsed but this DID associated different UCCX scriptWhen I remove service ivr on dial-peer 100 voip tcl application still invole particular dial-...
Hello Dev Guys,I want to make a script to insert the configs of CUCM automatc, how can i start this? Could you guys give some directions? Regards Leonardo Santana
Hi ,I have an application where the external user will dial in using toll free number to the CTI Route Point and based on the route pattern it should be redirected to a particular CTI Port ( Here for every meeting one CTI Port is allocated to suppor...
Trying to establish a TLS connection to CUCM and get this exception thrown when calling CiscoJtapiProperties.updateCertificate().java.lang.Exception: JTAPIProperties.updateCertificate : Certificate update failed, reason= 0 UpdateCertificate failed'W...
Hi all, we have CUCM 12.0 and i need to modify the inbound INVITE as per below example: Current From msg: From: "Maher" <sip:[email protected]>;tag=55180737_3200fdaa_a1bb118c-8443-4e82-81aa-a6148f5884bc and i need to replace JabberGuest from the ...
Hi, all I am newbie in the devnet world. I am finding some codes using suds and zeep to connect via AXL to the CUCM. There is any advantage to use suds or zeep or in end of the day, the result is exactly the same? Best Regards
Hi , I am using JTAPI for the first time and i have installed CiscoJtapiClient 8.5 on my local machine When i am trying to run the makecall functionality from my local machine i am getting the following error. TraceModule: couldn't create LogFileOutp...
Hello experts, are there any IMP developer guides for 11.5 version? I found these https://developer.cisco.com/site/im-and-presence/documents/ but they stop at version 10.5.2. Thank you.
Hi, I am using Cisco TSP (TAPI) on windows platform for CTI integration with Cisco platform. I am parking a call using undirected call parking feature. When Call Park Reversion Timer expires and the parked call comes back and rings on the extension I...
Hello, I new in the JTAPI area and I would like to ask it is possible to makecall to third party sip Directory Name ?Thanks
hi,everyone does anybody know "How to query the IP address of the cisco IP phone through API interface via Directory Number or other parameter". thanks
The url for GSAPI wsdl in the developer guide point to a 404 not found page https://d1nmyq4gcgsfi5.cloudfront.net/fileMedia/3cc79248-a407-476f-976c-c2c91086b715/Developer%20Guide.pdf see page 12 where can i find the wsdl file for GSAPI ? Tha...
We have a client that has a Bogen Multicom 2000 PA system and would like to access it from the Cisco ip phones. We have patched a cable to the system where the installer had marked and the other end is in a FXO port on a 2901. This 2901 is setup on M...
Hello. I'm looking to remove and replace the FROM header as the invite ingresses from Skype for Business into CUCM. Would the below script accomplish this? The invite currently just says "[email protected]:10.1.1.1". I'm looking to replace it with ...
| Subject | Author | Posted |
| 07-22-2026 03:11 PM | ||
| 12-14-2025 04:02 AM | ||
| 10-17-2025 12:27 AM | ||
| 07-22-2025 11:48 PM | ||
| 07-10-2025 11:24 PM |
