What "show call application services registry" does ?
paolo bevilacqua
I was under the impression that the CLI command in subject was to show which running applications had used the TCL/IVR command "service register" and the name. For example, B-ACD/AA uses "B-ACD-SERVICE" as a name.
However the command does not produce any output. So the question, if not the above, what is this CLI command for ?
Raised bug (CSCuu25791) for this issue.
Raghavendra
Raghavendra G V
It should show list of application sessions that have registered as a service, please check below link.
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s03_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1266669
Raghavendra
As mentioned that dose't work in my experience. I have tried with multiple type of application that register, on multiple IOS versions.
Raghavendra
