Integration web phone in asp.net app to use CUCM 8.6
hamzafliti1
I am searching an API to put it in my web application, in order to use clients pc as phone to call their customers from the web application, i dont have any idea about this API, do you have one?
Hamza
mpotluri
Level 5
Level 5
Hamza,
    You may want to look at web dialer API: Web Dialer.
    This API needs a IP phone to initiate a call and works only with Cisco Unified Communication Manager.
5 Replies 5
mpotluri
Level 5
Level 5
Hamza,
Second option is - you can also check jabber web sdk or guest sdk as per your requirement.
Thanks Mohan,
In this case the user can talk to the called number through the pc (using earphones) ? or from the IP Phone?
Web Dialer API needs IP phone or Jabber running in phone mode.
Thanks for the reply, but in this case(Web dialer),  can i use the PC to dial - speak-end call and since the application users must use the pc  to talk(as i saw that the Ip phone do the call when i click on dial from API of webdialer),
