2960x Stuck at POST: Thermal Tests : Begin
Loading "flash:/c2960x-universalk9-mz.152-6.E1.bin"...Verifying image flash:/c2960x-universalk9-mz.152-6.E1.bin.......................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.152-6.E1.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(6)E1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 06-Mar-18 06:58 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 833536
mifs[7]: Bytes available : 972800
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 1 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 3 files, 1 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 70110720
mifs[11]: Bytes available : 52075008
mifs[11]: mifs fsck took 0 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
balaji.bandi
Can you explain more :
1.What is the model of the device.
2. is this new or you upgrading the IOS ?
3. or working one crashed ?
BB
9 Replies 9
balaji.bandi
BB
1- 2960x-48LPS-L
2-c2960x-universalk9-mz.152-4.E6
3-Upgrade de firmware.
Hard reboot required: PULL the power cable. Do not use the "reload" command.
Hello! Have you solved this problem?
kim jakobsen
We had the same problem with a few stacks after upgrading to 15-2.4.E7
Removing the stack module while boot solved it so far, reinserting the stack module after boot brought member back into stack.
Tho the issue returns of the stack is rebooted again.
pimentelr1
unplugging power cord worked for me - had to do it twice - @Leo Laohoo  provided this answer in another thread
@pimentelr1
This is the correct alternative.
It definitely requires two reboots.
Rebooting only once won't work.
Minnesotakid
I just had this problem moving from 15.2(2)E3 to 15.2(7)E7. @pimentelr1 's suggestion of a double power cable reboot worked.
