C9300 (At layer 3 Interface) : ip multicast helper-map broadcast XXX.YYY.ZZZ.UUU 3 ttl 5
osr
How do configure this command or a workaround under a layer 3 interface in IOS-XE either cat3k or cat9k (c3850/c9300)? In the command above 3=ACL number
balaji.bandi
I have not tried in Cat 9300, may be try next week when i back to access to switches.
below syntax should work for you, try and advise.
 ip multicast helper-map broadcast x.x.x.x  ACLBB ttl 5
ip access-list extended ACLBB
 permit XXXX
 permit XXXX
BB
is that working ?
BB
