CSCue55239 - SIP Ghost call. SIP Port scanned from outside.
TJ Nielsen
I was getting hundreds of ghost calls every day on hundreds of endpoints.  This fix did the trick. Question: We are still using the H.323 standard but does anyone know if turning off the SIP listenport will not allow SIP calls directly to the codec?  Do they need to go through VCS from now on?
jeremy smith
Question:
In the Bug Search, I see this info (it won't let me cut and paste the rest of the page but it's bug search CSCue55239:
Last Modified:
Feb 3,2015
Status:
Fixed
Severity:
2 Severe
Product:
Cisco Telepresence Integrator C Series
Support Cases:
103
When it says "Status:  Fixed" and Known Fixed Releases: is a version older than the one we use, does that mean that the problem should be resolved from that firmware version forward? Also wondering if "Fixed" means that we still need to do the workaround to fix the problem on ALL versions of firmware, or just the ones prior to 6.2.0 ? Thanks.
Known Affected Releases:
(1)
5.1.2
(1)
6.2.0
