01-22-2019 06:05 AM
I see where this is applicable to 4.3.x code... but why would this still be showing up in 6.3.3 code?
asr9k-k9sec-supp, V 6.3.3[Default], Cisco Systems, at disk0:asr9k-k9sec-supp-6.3.3
Built on Tue Aug 28 18:31:48 EST 2018
RP/0/RSP1/CPU0:CORE-02#sh redundancy
Tue Jan 22 08:52:36.407 EST
Redundancy information for node 0/RSP1/CPU0:
Node 0/RSP1/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP0/CPU0) is in STANDBY role
Standby node in 0/RSP0/CPU0 is ready
Standby node in 0/RSP0/CPU0 is NSR-not-configured
Node 0/RSP1/CPU0 is in process group PRIMARY role
Process Redundancy Partner (0/RSP0/CPU0) is in BACKUP role
Backup node in 0/RSP0/CPU0 is ready
Backup node in 0/RSP0/CPU0 is NSR-ready
Group Primary Backup Status
v6-routing 0/RSP1/CPU0 0/RSP0/CPU0 Ready
mcast-routing 0/RSP1/CPU0 0/RSP0/CPU0 Ready
netmgmt 0/RSP1/CPU0 0/RSP0/CPU0 Ready
v4-routing 0/RSP1/CPU0 0/RSP0/CPU0 Ready
central-services 0/RSP1/CPU0 0/RSP0/CPU0 Ready
dsc 0/RSP1/CPU0 0/RSP0/CPU0 Ready
dlrsc 0/RSP1/CPU0 0/RSP0/CPU0 Ready
Reload and boot info
A9K-RSP880-LT-TR reloaded Tue Jan 22 00:24:49 2019: 8 hours, 27 minutes ago
Active node booted Tue Jan 22 01:30:12 2019: 7 hours, 22 minutes ago
Last switch-over Tue Jan 22 01:37:28 2019: 7 hours, 15 minutes ago
Standby node boot Tue Jan 22 02:41:18 2019: 6 hours, 11 minutes ago
Standby node last went not ready Tue Jan 22 02:42:28 2019: 6 hours, 10 minutes ago
Standby node last went ready Tue Jan 22 02:43:28 2019: 6 hours, 9 minutes ago
There have been 2 switch-overs since reload
Active node reload Cause: MBI-HELLO reloading node on receiving reload notification
Standby node reload "Cause: MBI-HELLO reloading node on receiving reload notification"
11-12-2019 09:06 PM
Hi, Do you have any update for this nsr-not-configure in the standby RSP.
11-20-2019 12:33 PM - edited 11-20-2019 12:34 PM
Hi, from IOS XR 6.2.X was fixed it, the node redundancy is when you'r using clusters nodes, an the Backup Node is related to the process and the RSP acting in Standby mode in the chassis.
I'll hope this help you!
