CSCur05434 - Emergency Responder evaluation for CVE-2014-6271 and CVE-2014-7169
vhinckley
So, is there going to be a COP file fix released for Emergency Responder or are we expected to know how to download and install the fixed version of Bash from Red Hat as the solution? For Call Manager, Unity and UCCX, there were COP files released...if this is not going to be the solution for ER, it would be nice if the bug report were clearer on the matter.
Adam Pawlowski
There is one posted under "CER Upgrade Patch" , at least for 10. The bug report is not clear on that at all.
Turns into: bash-3.2-33.el5_11.4
after installing the patch.
so, basically, it's hurry-up-and-wait for the fixes for prior versions...guess I just keep checking each week for a fix for 8.5. :(
The readme on the COP file taken from the CER 10.0 or CER 9.0 downloads section says it will install on 10.0(2), 10.0(1), 9.0(2), 9.0(1), 8.7(1), 8.6(1), and 8.5(1).
