CSCur57111 - VMWare tools not running after upgrade from 1.2 to 1.3
gthjohansson
Level 4
Level 4
I guess that we need to create a TAC case to be able to run this script as root ?
regards
Gudmundur
5 Replies 5
SDaniels1
I've upgrade from v1.2 to v1.3 (in a test-lab so far). I also found this problem of VMWare reporting the VM tools are not running, despite my changing the host type to RedHat6/x64.
Did you manage to figure out how to get ROOT access to be able to run the fix they mention?
https://tools.cisco.com/bugsearch/bug/CSCur57111/?referring_site=bugqvinvisibleredir
Thanks.
This issue was fixed in patch1 but reappeared in patch2
regards
Gudmundur
o.melendres
This issue was resolved with ISE 1.3 patch 1
Is necessary to apply the file:
ise-patchbundle-1.3.0.876-Auto1-125229.x86_64.tar.gz
this bug reappeared in patch 2
as for patch 1 I have had bad memory leak issues that seem to be resolved in patch 2
I just upgraded my test setup to ise 1.4 and this bug is still present there
So I was contacted by my VMWARE guys, that my 2 ISE Installations are not running the VMWARE tools - it is a upgraded ISE 1.3 with patch 2. And I´m not sure if I have to contact TAC about this, or if it is self solveable? Have you been able to fix this?
