CSCuw96608 - System Alarms need documentation - 1
Cedric Metzger
We have the same problem with Prime 3.2.0.0.258. Can anybody provide a solution or a reason of the bug?
archbran1
We are seeing the same Alarm running 3.2.0.0.258, did you ever find a resolution?
No unfortunately there's no answer from cisco to this bug. I think with upgrading to prime 3.4, the error is gone.
Same problem here with Prime 3.4 after upgrading from 3.2 :(
