CSCux29978 - Cisco ASA IKEv1 and IKEv2 Buffer Overflow Vulnerability - 1
cdegenkolb
im confused. In the secruity advisory to this bug https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20160210-asa-ike
it does not say "Affected" in the line of the ASA major version 9.1. So is 9.1 affected by this bug and do we need to upgrade to 9.1.(7) or not?
with regards
Christian
rvarelac
Level 7
Level 7
Hi Christian
According to the chart, the only version not affected is code 8.5 for 9.1 code you need to upgrade to 9.1.7 to be safe of this vulnerability.
Cisco ASA Major Release  First Fixed Release
7.21 Affected; migrate to 9.1(7) or later
8.21 Affected; migrate to 9.1(7) or later
8.31 Affected; migrate to 9.1(7) or later
8.4  8.4(7.30)
8.51 Not affected
8.61 Affected; migrate to 9.1(7) or later
8.7  8.7(1.18)
9.0 9.0(4.38)
9.1  9.1(7)
9.2  9.2(4.5)
9.3  9.3(3.7)
9.4  9.4(2.4)
9.5 9.5(2.2)
Hope it helps
-Randy-
15 Replies 15
rvarelac
Level 7
Level 7
Hi Christian
8.4  8.4(7.30)
8.51 Not affected
8.7  8.7(1.18)
9.0 9.0(4.38)
9.1  9.1(7)
9.2  9.2(4.5)
9.3  9.3(3.7)
9.4  9.4(2.4)
9.5 9.5(2.2)
Hope it helps
-Randy-
Hi All,
I know it's not specifically listed above or in the articles, and it's a very old EoL Version, but I have many firewalls still running an 8.0 or 8.1 version of the ASA Firmware. There seems to be a big gap between 7.2 and 8.2
Can anyone confirm whether these are truly affected or can they wait a little longer while we go through their upgrades/replacements?
Many thanks!
Cheers,
Ray
Hi Ray,
Unfortunately any version prior 8.4 has reach the End of software maintenance  and won't have a direct fix for this vulnerability. The only known not affected ASA version is 8.5 , any other version must be consider potentially vulnerable to this exploit.  You will need to schedule a maintenance window and upgrade your firewalls to 8.4 and above
Hope it helps
-Randy-
Please rate helpful post to help other users to find the answer quickly.
Thanks for the prompt reply Randy - Much appreciated! I shall get the ball rolling on this end then :) Cheers, Ray
Based on crash info posted, ASA SW version is 9.1(5). That could be the reason?
Saved_Crash
Thread Name: IKE Receiver
Page fault: Address not mapped
vector 0x0000000e
edi 0x00001720
esi 0xa954f534
ebp 0xa954f508
esp 0xa954f380
ebx 0xa9e54538
edx 0x00000000
ecx 0x00000000
eax 0x0000032f
error code 0x00000004
eip 0x08677870
cs 0x00000073
eflags 0x00013286
CR2 0x00001858
Cisco Adaptive Security Appliance Software Version 9.1(5)
Compiled on Thu 27-Mar-14 09:36 by builders
Hardware: ASA5510
Crashinfo collected on 05:40:47.402 CST Fri Feb 12 2016
Thx
MS
we are running version 8.2.4 (ASA 5520) - we see there is an interim software available which should fix the bug
8.2.5.59
http://www.cisco.com/web/software/280775065/45357/ASA-825-Interim-Release-Notes.html
Revision: Version 8.2.5(59) – 2/13/2016
Files: asa825-59-k8.bin, asa825-59-smp-k8.bin
Defects resolved since 8.2.5(58):
CSCux29978
ssl Cisco ASA IKEv1 and IKEv2 Buffer Overflow Vulnerability
CSCux42019
This will help us in the moment - we will upgrade soon to 5525-x Hardware and 9.5 Sw but this takes some time
regards
alex
Hi Randy,
we had a look at the CVRF where all affected Version are listed in detail. So to sum it up everything since the dawn of time is affected.
Thanks for your help.
with regards
Christian
Please note, I sadly hit the bug cscux45179 on my ASA after upgrading to 9.1(7) :(
Here my post: https://supportforums.cisco.com/discussion/12912621/cscux45179-ssl-sessions-stop-processing-unable-create-session-directory-error
Ok, I have a crash that I believe matches the vulnerability.
: Saved_Crash
vector 0x0000000e
edi 0x00001720
esi 0xa954f534
ebp 0xa954f508
esp 0xa954f380
ebx 0xa9e54538
edx 0x00000000
ecx 0x00000000
eax 0x0000032f
eip 0x08677870
cs 0x00000073
eflags 0x00013286
CR2 0x00001858
Hardware: ASA5510
Traceback:
0: 0x08063610
1: 0x08063651
2: 0x08065815
3: 0x08ef2943
4: 0xffffe410
5: 0x08678f73
6: 0x0806a25c
Stack dump: base:0xa954f408 size:196, active:196
entries above '==': return PC preceded by input parameters
entries below '==': local variables followed by saved regs
'==Fn': stack frame n, contains next stack frame
'*': stack pointer at crash
For example:
0xeeeeef00: 0x005d0707 : arg3
0xeeeeeefc: 0x00000159 : arg2
0xeeeeeef8: 0x005d0722 : arg1
0xeeeeeef4: 0x005d1754 : return PC
0xeeeeeef0: 0xeeeeef20 ==F2: stack frame F2
0xeeeeeeec: 0x00def9e0 : local variable
0xeeeeeee8: 0x0187df9e : local variable or saved reg
0xeeeeeee4: 0x01191548 : local variable or saved reg
0xeeeeeee0: 0x014dde20 : local variable or saved reg
0xa954f718-0xa954f6fc: 0x00000000
0xa954f6f8: 0x098a287a
0xa954f6f4: 0xa956c338
0xa954f6f0: 0xa951a2d8
0xa954f6ec-0xa954f6e8: 0x00000000
0xa954f6e4: 0x00000030
0xa954f6e0: 0xa11c0123
0xa954f6dc: 0x00000063
0xa954f6d8: 0x8000d4d0
0xa954f6d4: 0xa11ccdef
0xa954f6d0-0xa954f6cc: 0x0fffffff
0xa954f6c8-0xa954f6c0: 0x00000000
0xa954f6bc: 0x0b591d80
0xa954f6b8: 0x00000000
0xa954f6b4: 0xa954f658
0xa954f6b0: 0xa954f698
0xa954f6ac: 0x00000000
0xa954f6a8: 0xa91cf398
0xa954f6a4-0xa954f684: 0x00000000
0xa954f680: 0x0ad487f4
0xa954f67c: 0x0805e730
0xa954f678: 0x0a850680
0xa954f674: 0x00000003
0xa954f670: 0x00010042
0xa954f66c: 0x0b89c0c0
0xa954f668: 0xa954f658
0xa954f664: 0xa951a258
0xa954f660: 0xa956c2b8
0xa954f65c: 0xa921182c
0xa954f658: 0xa954f6a8
0xa954f654: 0xdeadfeed
0xa954f650-0xa954f64c: 0x00000000
0xa954f648: 0x0805f33c
0xa954f644: 0xa956c288
0xa954f640: 0xa951a228
0xa954f63c-0xa954f638: 0x00000000
0xa954f634: 0x00000084
0xa954f630: 0xa11c0123
0xa954f62c: 0x000000b3
0xa954f628: 0x8000d4d0
0xa954f624: 0x00000000
0xa954f620: 0xa11ccdef
0xa954f61c-0xa954f60c: 0x00000000 ==F3
0xa954f608-0xa954f57c: 0x12345678
0xa954f578: 0x0806a249
0xa954f574: 0xa954f550
0xa954f570: 0xa954f618
0xa954f56c: 0x00000000
0xa954f568: 0xffffefc8
0xa954f564: 0xa91cf208
0xa954f560: 0x00000000
0xa954f55c-0xa954f554: 0x12345678
0xa954f550: 0x0aeaae38
0xa954f54c: 0x0806a25c
0xa954f548: 0xa954f618 ==F2
0xa954f544: 0x00000000
0xa954f540: 0xffffefc8
0xa954f53c: 0xa91cf208
0xa954f538: 0x00000002
0xa954f534: 0x00000000
0xa954f530: 0x0035b8ea
0xa954f52c: 0x12345678
0xa954f528: 0xa9e54538
0xa954f524-0xa954f51c: 0x12345678
0xa954f518: 0x00000000
0xa954f514: 0xa954f534
0xa954f510: 0xa920c758
0xa954f50c: 0x08678f73
0xa954f508: 0xa954f548 ==F1
0xa954f504: 0xa9e5453c
0xa954f500: 0xa954f534
0xa954f4fc: 0xa954f538
0xa954f4f8: 0x00000000
0xa954f4f4: 0x006b9a75
0xa954f4f0: 0x9a58df3e
0xa954f4ec: 0x098aedfa
0xa954f4e8: 0xa954f508
0xa954f4e4: 0xa91cf208
0xa954f4e0: 0x00000000
0xa954f4dc: 0x00000001
0xa954f4d8: 0x00000004
0xa954f4d4: 0xa954f4fc
0xa954f4d0: 0x00000000
0xa954f4cc: 0x0806b89a
0xa954f4c8: 0xa954f508
0xa954f4c4: 0x00000001
0xa954f4c0: 0xa9e54538
0xa954f4bc: 0x00000000
0xa954f4b8: 0xa954f4c8
0xa954f4b4: 0xa9000700
0xa954f4b0: 0x00000000
0xa954f4ac: 0x098a8865
0xa954f4a8: 0xa954f4c8
0xa954f4a4: 0x00001fa4
0xa954f4a0: 0x00001f80
0xa954f49c: 0x098a8c31
0xa954f498: 0xa954f4c8
0xa954f494-0xa954f490: 0xa9000008
0xa954f48c: 0x00001f80
0xa954f488: 0x00000001
0xa954f484: 0x00000000
0xa954f480: 0xa92106a0
0xa954f47c: 0x00000000
0xa954f478: 0xbf06829e
0xa954f474-0xa954f470: 0x00000000
0xa954f46c: 0xa92106a0
0xa954f468: 0x00000000
0xa954f464: 0xbf06829e
0xa954f460: 0x00000000
0xa954f45c: 0x08f63537
0xa954f458: 0xa954f468
0xa954f454: 0x12345678
0xa954f450: 0xcab24cc8
0xa954f44c: 0x00000000
0xa954f448: 0x08f63537
0xa954f444: 0xa954f468
0xa954f440: 0x12345678
0xa954f43c: 0xcab24cc8
0xa954f438-0xa954f434: 0x00000000
0xa954f430: 0xa92106a0
0xa954f42c: 0x00000000
0xa954f428: 0xbf06829e
0xa954f424: 0x00000000
0xa954f420: 0x9c180000
0xa954f41c: 0x0000a921
0xa954f418: 0x06a00000
0xa954f414: 0x0000bf06
0xa954f410: 0x829e0000
0xa954f40c: 0x000001f4
Process virtual address map:
08048000-0a771000 r-xp 00000000 00:01 900 /asa/bin/lina
0a771000-0a773000 r-xp 02728000 00:01 900 /asa/bin/lina
0a773000-0ad53000 rwxp 0272a000 00:01 900 /asa/bin/lina
0ad53000-0b89f000 rwxp 0ad53000 00:00 0 [heap]
a5239000-a523a000 rwxp a5239000 00:00 0
a523a000-a523b000 rwxs fff00000 00:0e 1189 /dev/mem
a523b000-a533c000 rwxp a523b000 00:00 0
a533c000-a5340000 rwxs 00000000 00:08 2284 /dev/zero (deleted)
a5340000-a5745000 rwxp a5340000 00:00 0
a5745000-a5765000 rwxs f8100000 00:0e 1189 /dev/mem
a5765000-a5785000 rwxs f8200000 00:0e 1189 /dev/mem
a5785000-a57a5000 rwxs f8220000 00:0e 1189 /dev/mem
a57a5000-a57c5000 rwxs f8240000 00:0e 1189 /dev/mem
a57c5000-a57e5000 rwxs f8260000 00:0e 1189 /dev/mem
a57e5000-a57e6000 rwxs ffb00000 00:0e 1189 /dev/mem
a57e6000-a57f6000 rwxs fff00000 00:0e 1189 /dev/mem
a57f6000-a57fe000 rwxs 000d8000 00:0e 1189 /dev/mem
a57fe000-a57ff000 rwxs f8340000 00:0e 1189 /dev/mem
a57ff000-a5800000 rwxs f8300000 00:0e 1189 /dev/mem
a5800000-a8c0a000 rwxs 00000000 00:0e 1790 /dev/udma0
a9000000-ac000000 rwxs 00000000 00:0b 0 /SYSV00000002 (deleted)
ac000000-ac400000 r-xs 03000000 00:0b 0 /SYSV00000002 (deleted)
ac400000-ac800000 rwxs 03400000 00:0b 0 /SYSV00000002 (deleted)
ac800000-acc00000 r-xs 03800000 00:0b 0 /SYSV00000002 (deleted)
acc00000-ad000000 r-xs 03c00000 00:0b 0 /SYSV00000002 (deleted)
ad000000-dbc00000 rwxs 04000000 00:0b 0 /SYSV00000002 (deleted)
dbf54000-dbf57000 rwxp dbf54000 00:00 0
dbf57000-dc090000 r-xp 00000000 00:01 168 /lib/libc-2.9.so
dc090000-dc091000 ---p 00139000 00:01 168 /lib/libc-2.9.so
dc091000-dc093000 r-xp 00139000 00:01 168 /lib/libc-2.9.so
dc093000-dc094000 rwxp 0013b000 00:01 168 /lib/libc-2.9.so
dc094000-dc098000 rwxp dc094000 00:00 0
dc098000-dc0a2000 r-xp 00000000 00:01 173 /lib/libgcc_s.so.1
dc0a2000-dc0a3000 r-xp 00009000 00:01 173 /lib/libgcc_s.so.1
dc0a3000-dc0a4000 rwxp 0000a000 00:01 173 /lib/libgcc_s.so.1
dc0a4000-dc0c8000 r-xp 00000000 00:01 184 /lib/libm-2.9.so
dc0c8000-dc0c9000 r-xp 00023000 00:01 184 /lib/libm-2.9.so
dc0c9000-dc0ca000 rwxp 00024000 00:01 184 /lib/libm-2.9.so
dc0ca000-dc0d3000 r-xp 00000000 00:01 172 /lib/libudev.so.0.5.0
dc0d3000-dc0d4000 r-xp 00008000 00:01 172 /lib/libudev.so.0.5.0
dc0d4000-dc0d5000 rwxp 00009000 00:01 172 /lib/libudev.so.0.5.0
dc0d5000-dc0e0000 r-xp 00000000 00:01 625 /usr/lib/libcgroup.so.1.0.34
dc0e0000-dc0e1000 r-xp 0000a000 00:01 625 /usr/lib/libcgroup.so.1.0.34
dc0e1000-dc0e2000 rwxp 0000b000 00:01 625 /usr/lib/libcgroup.so.1.0.34
dc0e2000-dc6db000 rwxp dc0e2000 00:00 0
dc6db000-dc6e2000 r-xp 00000000 00:01 201 /lib/librt-2.9.so
dc6e2000-dc6e3000 r-xp 00006000 00:01 201 /lib/librt-2.9.so
dc6e3000-dc6e4000 rwxp 00007000 00:01 201 /lib/librt-2.9.so
dc6e4000-dc6e6000 r-xp 00000000 00:01 175 /lib/libdl-2.9.so
dc6e6000-dc6e7000 r-xp 00001000 00:01 175 /lib/libdl-2.9.so
dc6e7000-dc6e8000 rwxp 00002000 00:01 175 /lib/libdl-2.9.so
dc6e8000-dc6e9000 rwxp dc6e8000 00:00 0
dc6e9000-dc6fd000 r-xp 00000000 00:01 170 /lib/libpthread-2.9.so
dc6fd000-dc6fe000 r-xp 00013000 00:01 170 /lib/libpthread-2.9.so
dc6fe000-dc6ff000 rwxp 00014000 00:01 170 /lib/libpthread-2.9.so
dc6ff000-dc701000 rwxp dc6ff000 00:00 0
dc701000-dc71c000 r-xp 00000000 00:01 399 /usr/lib/libexpat.so.1.5.2
dc71c000-dc71e000 r-xp 0001a000 00:01 399 /usr/lib/libexpat.so.1.5.2
dc71e000-dc71f000 rwxp 0001c000 00:01 399 /usr/lib/libexpat.so.1.5.2
dc71f000-dc7cd000 r-xp 00000000 00:01 188 /lib/libstdc++.so.6.0.10
dc7cd000-dc7d1000 r-xp 000ad000 00:01 188 /lib/libstdc++.so.6.0.10
dc7d1000-dc7d2000 rwxp 000b1000 00:01 188 /lib/libstdc++.so.6.0.10
dc7d2000-dc7d8000 rwxp dc7d2000 00:00 0
dc7d8000-dc7dd000 r-xp 00000000 00:01 664 /usr/lib/libnuma.so.1
dc7dd000-dc7de000 r-xp 00004000 00:01 664 /usr/lib/libnuma.so.1
dc7de000-dc7df000 rwxp 00005000 00:01 664 /usr/lib/libnuma.so.1
dc7e0000-dc7e2000 rwxp dc7e0000 00:00 0
dc7e2000-dc7fe000 r-xp 00000000 00:01 163 /lib/ld-2.9.so
dc7fe000-dc7ff000 r-xp 0001b000 00:01 163 /lib/ld-2.9.so
dc7ff000-dc800000 rwxp 0001c000 00:01 163 /lib/ld-2.9.so
dcfeb000-dd000000 rwxp dcfeb000 00:00 0 [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
Globl mempool: least_addr=0xa9000000 top=0xb3fe0eb0 dv=0x00000000 mflags=0x7
DMA mempool: least_addr=0xa5800000 top=0xa81d2328 dv=0xa76a34b8 mflags=0x7
Current Block:
Block : 0xa9062b20
B-base : 0xa9062e04
B-size : 152
B-rptr : 0xa9062e98
B-hptr : 0xa9062e98
B-allocd : 0x08586ed0
B-freed : 0x0806a25c
B-location: 0x00000088
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #0 [0xa9062bc0] ext-dump 0 of (Block) from Current Block extra dump
0xa9062ba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062bb0: 00 00 00 00 ff ff ff ff 00 00 00 00 00 00 00 00 | ................
0xa9062bc0: 00 00 00 00 00 00 00 00 00 00 00 00 88 00 00 00 | ................
0xa9062bd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062be0: 78 4b 07 00 00 00 00 00 00 00 00 00 00 00 00 00 | xK..............
0xa9062bf0: 00 00 00 00 98 2e 06 a9 00 00 00 00 00 00 00 00 | ................
0xa9062c00: 00 00 00 00 00 00 00 00 60 fb 46 68 00 00 00 00 | ........`.Fh....
0xa9062c10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062c30: 00 00 00 00 00 00 00 00 00 00 00 00 5c a2 06 08 | ............\...
Region #1 [0xa9062e98] ext-dump 1 of (Block) from Current Block extra dump
0xa9062e78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062e88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062e98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062ea8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062eb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062ec8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062ed8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062ee8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062ef8: 00 00 00 00 58 3b 10 a9 00 00 00 00 00 00 00 00 | ....X;..........
0xa9062f08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #2 [0xa9062f38] ext-dump 2 of (Block) from Current Block extra dump
0xa9062f18: 58 3b 10 a9 00 00 00 00 20 9b 0d a9 cc cc bb bb | X;...... .......
0xa9062f28: 67 ff 01 00 04 32 06 a9 9c 32 06 a9 d0 6e 58 08 | g....2...2...nX.
0xa9062f38: 0a 00 00 00 00 00 00 00 00 00 00 00 30 39 05 08 | ............09..
0xa9062f48: 20 1f 59 0b 00 00 00 00 00 00 00 00 00 00 00 00 | .Y.............
0xa9062f58: ff ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 | ................
0xa9062f68: 00 c0 00 00 98 32 06 a9 98 32 06 a9 98 32 06 a9 | .....2...2...2..
0xa9062f78: 98 32 06 a9 d0 dd ff a5 e4 dd ff a5 00 00 00 00 | .2..............
0xa9062f88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062f98: c0 00 2c 01 60 30 06 a9 00 00 00 00 00 00 00 00 | ..,.`0..........
0xa9062fa8: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff | ................
Current Connection:
Conn : 0xb0158d40
C-flow : 0xb0158e1c 0xb0158f44
C-flowcnt : 2
C-flags : 0x1000000
C-par_conn: 0x00000000
C-chd_conn: 0x00000000
C-sib_conn: 0x00000000
C-inspect : 0x00000000
C-inspect2: 0x00000000
C-ids : 0x00000000
C-cxsc : 0x00000000
C-conn_lck_own: 0x0
C-conn_lck_cnt: 0x0
C-work_que: 0xffffffff
C-pur_call: 0x00000000
C-pur_calb: 0x089c7dd0
C-tim_call: 0x08aa8610
C-tim_calq: 0xaa6b8340
Flow : C-FLOW_SRC 0xb0158e1c
F-SrcIP : 0xfd01a8c0 (192.168.1.253)
F-DstIP : 0x973bf5ad (173.245.59.151)
F-SrcPort: 0x2cff (65324)
F-DstPort: 0x3500 (53)
F-ESrcIP : 0xcbb24cc8 (200.76.178.203)
F-EDstIP : 0x973bf5ad (173.245.59.151)
F-ESrcPrt: 0x2cff (65324)
F-EDstPrt: 0x3500 (53)
F-flags : 0x2000000
F-flags2 : 0x10000
F-flags3 : 0x18000
F-flags4 : 0x100
F-bytes : 50
F-disp-refcnt : 1964
F-host : 0xaa860b40
H-addr : 0xfd01a8c0
H-refcnt : 1978
H-tcpmss : 1380
Flow : C-FLOW_DEST 0xb0158f44
F-SrcIP : 0x973bf5ad (173.245.59.151)
F-DstIP : 0xcbb24cc8 (200.76.178.203)
F-SrcPort: 0x3500 (53)
F-DstPort: 0x2cff (65324)
F-ESrcIP : 0x973bf5ad (173.245.59.151)
F-EDstIP : 0xfd01a8c0 (192.168.1.253)
F-ESrcPrt: 0x3500 (53)
F-EDstPrt: 0x2cff (65324)
F-flags : 0x2
F-flags2 : 0x10000
F-flags3 : 0x18000
F-flags4 : 0x0
F-bytes : 0
F-disp-refcnt : 1965
F-host : 0xb05b3a40
H-addr : 0x973bf5ad
H-refcnt : 500
H-tcpmss : 0
Region #3 [0xb0158e1c] ext-dump 0 of (Conn) from Current Conn extra dump
0xb0158dfc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158e0c: 00 d6 11 7e 03 00 00 00 00 00 00 01 ff ff ff ff | ...~............
0xb0158e1c: 01 00 00 00 8c db 37 06 02 00 00 00 40 8d 15 b0 | ......7.....@...
0xb0158e2c: 40 b8 68 aa 48 b0 4d a9 68 b8 7b ad 01 00 00 00 | @.h.H.M.h.{.....
0xb0158e3c: 18 03 00 00 80 89 a5 ad 09 16 00 00 00 00 00 00 | ................
0xb0158e4c: 00 00 00 00 00 00 00 00 b8 72 b8 72 00 00 00 02 | .........r.r....
0xb0158e5c: 00 00 01 00 00 80 01 00 00 01 00 00 32 00 00 00 | ............2...
0xb0158e6c: 44 8f 15 b0 40 0b 86 aa a0 8f 15 b0 ff 2c 00 35 | D...@........,.5
0xb0158e7c: 11 00 00 00 00 00 00 00 c0 a8 01 fd 00 00 00 00 | ................
0xb0158e8c: 00 00 00 00 00 00 00 00 00 00 00 00 ad f5 3b 97 | ..............;.
Region #4 [0xb0158ebc] ext-dump 1 of (Conn) from Current Conn extra dump
0xb0158e9c: 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 | ................
0xb0158eac: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158ebc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158ecc: 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | 2...............
0xb0158edc: 00 00 01 00 00 00 00 00 00 00 00 00 80 34 2b ab | .............4+.
0xb0158eec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158efc: 00 00 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #5 [0xab2b3480] ext-dump 2 of (Conn) from Current Conn extra dump
0xab2b3460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xab2b3470: 00 00 00 00 00 00 00 00 00 00 00 00 28 3b 2b ab | ............(;+.
0xab2b3480: ef be ad de 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xab2b3490: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xab2b34a0: 00 00 00 00 ff ff ff ff 60 e0 40 0b 80 34 2b ab | ........`.@..4+.
0xab2b34b0: 06 00 00 00 a5 07 00 00 00 00 00 00 00 00 00 00 | ................
0xab2b34c0: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xab2b34d0: 48 b0 4d a9 00 00 00 00 c0 a8 01 fd e8 7e a4 ad | H.M..........~..
0xab2b34e0: d8 7d 60 ad 00 00 00 00 68 b8 7b ad 00 00 00 00 | .}`.....h.{.....
0xab2b34f0: c8 4c b2 cb 98 00 00 00 d0 7c 6d ae d8 7c 6d ae | .L.......|m..|m.
Region #6 [0xaa68b840] ext-dump 3 of (Conn) from Current Conn extra dump
0xaa68b820: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b830: 00 00 00 00 00 00 00 00 00 00 00 00 90 f1 48 a9 | ..............H.
0xaa68b840: 01 00 00 00 f1 17 a8 a3 ac 07 00 00 05 00 00 00 | ................
0xaa68b850: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b860: 00 00 00 00 00 00 00 00 00 00 00 00 40 b5 30 a9 | ............@.0.
0xaa68b870: 00 00 00 00 c0 b8 30 a9 00 00 00 00 80 b5 30 a9 | ......0.......0.
0xaa68b880: 00 00 00 00 00 b5 30 a9 00 00 00 00 00 a2 30 a9 | ......0.......0.
0xaa68b890: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b8a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b8b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #7 [0xb0158f44] ext-dump 4 of (Conn) from Current Conn extra dump
0xb0158f24: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f34: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f44: 01 00 00 00 40 52 f2 8e 02 00 00 00 40 8d 15 b0 | ....@R......@...
0xb0158f54: 40 b9 68 aa 68 b8 7b ad 48 b0 4d a9 18 03 00 00 | @.h.h.{.H.M.....
0xb0158f64: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158f74: 00 00 00 00 00 00 00 00 47 8d 47 8d 02 00 00 00 | ........G.G.....
0xb0158f84: 00 00 01 00 00 80 01 00 00 00 00 00 00 00 00 00 | ................
0xb0158f94: 1c 8e 15 b0 40 3a 5b b0 78 8e 15 b0 00 35 ff 2c | ....@:[.x....5.,
0xb0158fa4: 11 00 00 00 00 00 00 00 ad f5 3b 97 00 00 00 00 | ..........;.....
0xb0158fb4: 00 00 00 00 00 00 00 00 00 00 00 00 c8 4c b2 cb | .............L..
Region #8 [0xb0158fe4] ext-dump 5 of (Conn) from Current Conn extra dump
0xb0158fc4: 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 | ................
0xb0158fd4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158fe4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158ff4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159004: 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159014: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159024: 00 00 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159034: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159044: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0159054: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #9 [0xaa68b940] ext-dump 6 of (Conn) from Current Conn extra dump
0xaa68b920: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b930: 00 00 00 00 00 00 00 00 00 00 00 00 90 f1 48 a9 | ..............H.
0xaa68b940: 01 00 00 00 00 76 10 a1 ad 07 00 00 05 00 00 00 | .....v..........
0xaa68b950: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b960: 00 00 00 00 00 00 00 00 00 00 00 00 40 b5 30 a9 | ............@.0.
0xaa68b970: 00 00 00 00 c0 b8 30 a9 00 00 00 00 80 b5 30 a9 | ......0.......0.
0xaa68b980: 00 00 00 00 00 b5 30 a9 00 00 00 00 c0 9f 30 a9 | ......0.......0.
0xaa68b990: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b9a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xaa68b9b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #10 [0xb0158d48] ext-dump 7 of (Conn) from Current Conn extra dump
0xb0158d28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb0158d38: 00 00 00 00 88 a8 3d b0 c1 10 a1 c0 6a 48 9d 6a | ......=.....jH.j
0xb0158d48: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 | ................
0xb0158d58: 48 8d 15 b0 ff ff ff ff 00 00 00 00 00 00 00 00 | H...............
0xb0158d68: d0 7d 9c 08 00 00 00 00 00 00 00 00 ff ff ff ff | .}..............
0xb0158d78: 48 8d 15 b0 80 b9 65 6c 9b 42 43 00 00 00 00 00 | H.....el.BC.....
0xb0158d88: 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 | ................
0xb0158d98: 00 00 00 00 00 00 00 00 00 00 00 00 10 86 aa 08 | ................
0xb0158da8: 00 00 00 00 02 00 00 00 40 83 6b aa 98 cd 6b aa | ........@.k...k.
0xb0158db8: 34 6b 0f b0 90 cd 6b aa 5a 8d 15 b0 0c 50 15 01 | 4k....k.Z....P..
TSD dump (core0 tp=0x0b434380):
core0: dp_executing_cp=1 tid=0xa91cf208 latest purge=0x0 calq=0xb221bc34
async_cnt=0 purgatory=0x00000000 async_lock=0x00000000 dor_spinlock=0x00000000
Dumping latest_calq_entry 0xb221bc34
0xb221bbf4: ff ff ff ff c8 bb 21 b2 80 03 1d 7b 9a 42 43 00 | ......!....{.BC.
0xb221bc04: 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 | ................
0xb221bc14: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb221bc24: 10 86 aa 08 00 00 00 00 02 00 00 00 b0 c3 6c aa | ..............l.
0xb221bc34: 58 95 6d aa f4 48 c3 b1 50 95 6d aa da bb 21 b2 | X.m..H..P.m...!.
0xb221bc44: a5 50 15 01 00 00 00 00 00 00 00 00 00 00 00 00 | .P..............
0xb221bc54: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xb221bc64: da bb 21 b2 00 00 00 00 80 54 1c 7b 9a 42 43 00 | ..!......T.{.BC.
Selective memory dump: DT(Data, default) TX(Text) UD(Uninit-Data)
BA(Bad) ID(Init-Data) UK(Unknown)
Region #0 [0xa954f380] from tback F0
0xa954f360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f380: 20 2b 06 a9 02 00 00 00 04 00 00 00 53 b5 af 09 | +..........S...
0xa954f390: 44 d8 ae 09 f4 01 00 00 0e f4 54 a9 18 9c 00 00 | D.........T.....
0xa954f3a0: 78 56 34 12 78 56 34 12 0b b4 19 00 e8 f3 54 a9 | xV4.xV4.......T.
0xa954f3b0: a0 06 21 a9 00 00 00 00 78 56 f4 01 70 83 67 08 | ..!.....xV..p.g.
0xa954f3c0: 02 00 00 00 16 68 73 00 1d 00 00 00 f0 a7 4c a9 | .....hs.......L.
0xa954f3d0: 38 50 2f ae 2c 5d df a5 40 00 00 00 20 4b 0a a9 | 8P/.,]..@... K..
0xa954f3e0: 49 5d df a5 2c 5d df a5 20 17 00 00 78 56 34 12 | I]..,].. ...xV4.
0xa954f3f0: 78 56 34 12 b0 1f 00 00 00 00 00 00 c8 4c b2 ca | xV4..........L..
Region #1 [0xa954b600] from #0 (malloc_header) magic off 0
0xa954b5e0: 18 00 00 00 79 00 00 00 ef cd 1c a1 00 00 00 00 | ....y...........
0xa954b5f0: 10 32 e3 5e ef cd ee f3 d0 d4 00 80 33 40 00 00 | .2.^........3@..
0xa954b600: 23 01 1c a1 00 40 00 00 00 00 00 00 00 00 00 00 | #....@..........
0xa954b610: f8 61 51 a9 58 82 56 a9 b1 a7 06 08 00 00 00 00 | .aQ.X.V.........
0xa954b620: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954b630: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954b640: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954b650: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954b660: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954b670: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
malloc_header:0xa954b600
M-size : 0x4000
M-allocd : 0x0806a7b1
Region #2 [0xa9062b20] from #0 tback F0 dump off 0x00000000
0xa9062b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9062b10: 00 00 00 00 00 00 00 00 58 3b 10 a9 00 00 00 00 | ........X;......
0xa9062b20: 20 7f 05 a9 cc cc bb bb 67 ff 01 00 04 2e 06 a9 | ......g.......
0xa9062b30: 9c 2e 06 a9 d0 6e 58 08 fc 8b 52 00 00 00 00 00 | .....nX...R.....
0xa9062b40: 00 00 00 00 30 39 05 08 20 1f 59 0b 00 00 00 00 | ....09.. .Y.....
0xa9062b50: 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff | ................
0xa9062b60: 00 00 00 00 00 00 00 00 00 c0 00 00 98 2e 06 a9 | ................
0xa9062b70: 98 2e 06 a9 98 2e 06 a9 98 2e 06 a9 fc 32 e8 a5 | .............2..
0xa9062b80: 84 38 ce a5 00 ff ff 00 00 00 00 00 00 00 00 00 | .8..............
0xa9062b90: 00 00 00 00 00 00 00 00 c0 00 2c 01 60 2c 06 a9 | ..........,.`,..
Block : 0xa9062b20
B-base : 0xa9062e04
B-size : 152
B-rptr : 0xa9062e98
B-hptr : 0xa9062e98
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #3 [0xa9062bc0] ext-dump 0 of (Block) from #2
Region #4 [0xa9062e98] ext-dump 1 of (Block) from #2
Region #6 [UK:0x09afb550] from #0 tback F0 dump off 0x0000000c
0x09afb530: 00 73 75 62 6e 65 74 3a 20 20 00 4c 6f 61 64 69 | .subnet: .Loadi
0x09afb540: 6e 67 20 00 25 73 3a 20 4e 55 4c 4c 20 62 6c 6f | ng .%s: NULL blo
0x09afb550: 63 6b 00 25 73 3a 20 45 6d 70 74 79 20 62 6c 6f | ck.%s: Empty blo
0x09afb560: 63 6b 00 25 73 3a 20 49 6e 76 61 6c 69 64 20 68 | ck.%s: Invalid h
0x09afb570: 61 6e 64 6c 65 00 6c 6f 63 61 6c 69 7a 65 64 00 | andle.localized.
0x09afb580: 75 64 70 2f 25 73 2f 25 64 2f 25 64 00 69 6b 65 | udp/%s/%d/%d.ike
0x09afb590: 5f 72 65 63 65 69 76 65 72 2e 63 00 75 64 70 2f | _receiver.c.udp/
0x09afb5a0: 25 73 2f 76 36 2f 25 64 2f 25 64 00 46 61 69 6c | %s/v6/%d/%d.Fail
0x09afb5b0: 65 64 20 74 6f 20 6f 70 65 6e 20 22 25 73 22 20 | ed to open "%s"
0x09afb5c0: 0a 00 25 73 3a 20 50 6f 72 74 20 25 75 20 6e 6f | ..%s: Port %u no
Region #7 [UK:0x09aed844] from #0 tback F0 dump off 0x00000010
0x09aed824: ff ff ff ff ff ff ff ff 00 00 00 00 03 00 00 00 | ................
0x09aed834: 00 00 00 00 01 00 00 00 02 00 00 00 ff ff ff ff | ................
0x09aed844: 69 6b 65 5f 72 65 63 65 69 76 65 72 5f 70 72 6f | ike_receiver_pro
0x09aed854: 63 65 73 73 5f 64 61 74 61 00 69 6b 65 5f 69 6f | cess_data.ike_io
0x09aed864: 5f 73 65 6e 64 00 69 6b 65 5f 69 6f 5f 73 65 74 | _send.ike_io_set
0x09aed874: 5f 62 6c 6f 63 6b 69 6e 67 00 00 00 35 af 67 08 | _blocking...5.g.
0x09aed884: 25 af 67 08 15 af 67 08 05 af 67 08 f5 ae 67 08 | %.g...g...g...g.
0x09aed894: e5 ae 67 08 d3 ae 67 08 d3 ae 67 08 73 ae 67 08 | ..g...g...g.s.g.
0x09aed8a4: 0d ae 67 08 fd ad 67 08 ec ad 67 08 db ad 67 08 | ..g...g...g...g.
0x09aed8b4: c2 ad 67 08 b2 ad 67 08 a3 ad 67 08 99 ad 67 08 | ..g...g...g...g.
Region #9 [0xa954f40c] from #0 tback F0 dump off 0x00000018
0xa954f3ec: 78 56 34 12 78 56 34 12 b0 1f 00 00 00 00 00 00 | xV4.xV4.........
0xa954f3fc: c8 4c b2 ca 78 56 34 12 68 f4 54 a9 37 35 f6 08 | .L..xV4.h.T.75..
0xa954f40c: f4 01 00 00 00 00 9e 82 06 bf 00 00 00 00 a0 06 | ................
0xa954f41c: 21 a9 00 00 00 00 18 9c 00 00 00 00 9e 82 06 bf | !...............
0xa954f42c: 00 00 00 00 a0 06 21 a9 00 00 00 00 00 00 00 00 | ......!.........
0xa954f43c: c8 4c b2 ca 78 56 34 12 68 f4 54 a9 37 35 f6 08 | .L..xV4.h.T.75..
0xa954f44c: 00 00 00 00 c8 4c b2 ca 78 56 34 12 68 f4 54 a9 | .....L..xV4.h.T.
0xa954f45c: 37 35 f6 08 00 00 00 00 9e 82 06 bf 00 00 00 00 | 75..............
0xa954f46c: a0 06 21 a9 00 00 00 00 00 00 00 00 9e 82 06 bf | ..!.............
0xa954f47c: 00 00 00 00 a0 06 21 a9 00 00 00 00 01 00 00 00 | ......!.........
Region #10 [0xa954b600] from #9 (malloc_header) magic off 0
M-size : 0x4000
Region #15 [0xa92106a0] from #0 tback F0 dump off 0x00000030
0xa9210680: 00 00 00 00 00 00 00 00 90 f0 20 a9 20 ea 26 a9 | .......... . .&.
0xa9210690: f3 c3 85 09 00 00 00 00 45 36 27 18 98 06 21 a9 | ........E6'...!.
0xa92106a0: 88 45 21 a9 00 00 00 00 00 00 00 00 00 00 00 00 | .E!.............
0xa92106b0: 00 00 00 00 9d c9 a3 15 50 00 00 00 50 00 00 00 | ........P...P...
0xa92106c0: 34 00 00 00 34 00 00 00 32 00 00 00 1e 00 00 00 | 4...4...2.......
0xa92106d0: 21 00 00 00 32 00 00 00 00 00 00 00 00 00 00 00 | !...2...........
0xa92106e0: 00 00 08 00 01 00 00 00 33 00 00 00 00 00 00 00 | ........3.......
0xa92106f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9210700: 57 61 74 63 68 65 72 20 49 6e 66 6f 00 00 00 00 | Watcher Info....
0xa9210710: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #17 [TX:0x08678370] from #0 tback F0 dump off 0x0000003c
0x08678350: 2c 9d cb ff 89 1c 24 31 db e8 b2 6b 23 01 e9 d7 | ,.....$1...k#...
0x08678360: f8 ff ff 8d b6 00 00 00 00 8d bc 27 00 00 00 00 | ...........'....
0x08678370: 55 89 e5 56 53 83 ec 60 8b 75 0c c7 04 24 16 00 | U..VS..`.u...$..
0x08678380: 00 00 e8 49 6a 23 01 85 c0 89 c3 0f 84 d7 00 00 | ...Ij#..........
0x08678390: 00 8b 06 89 03 8b 46 04 89 43 04 8b 46 08 89 43 | ......F..C..F..C
0x086783a0: 08 8b 46 0c 89 43 0c 8b 46 10 89 43 10 0f b7 46 | ..F..C..F..C...F
0x086783b0: 14 66 89 43 14 8b 55 dc 8b 4d d8 8b 45 e0 c7 45 | .f.C..U..M..E..E
0x086783c0: d4 00 00 00 00 89 55 f0 89 4d ec 89 45 f4 c7 45 | ......U..M..E..E
0x086783d0: d0 00 00 00 00 c7 45 e4 00 00 00 00 c7 45 e8 00 | ......E......E..
0x086783e0: 00 00 00 89 54 24 20 89 4c 24 1c c7 44 24 14 00 | ....T$ .L$..D$..
Region #20 [0xa94ca7f0] from #0 tback F0 dump off 0x0000004c
0xa94ca7d0: a0 fb 32 ae 00 00 00 00 01 00 00 00 08 07 00 00 | ..2.............
0xa94ca7e0: 1e 00 00 00 c8 00 00 00 90 01 00 00 00 00 00 00 | ................
0xa94ca7f0: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94ca800: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94ca810: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94ca820: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94ca830: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94ca840: 00 00 00 00 19 00 00 00 00 00 00 00 09 00 00 00 | ................
0xa94ca850: 09 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 | ................
0xa94ca860: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #21 [0xa94c9888] from #20 (malloc_header) magic off 0
0xa94c9868: 00 00 00 00 40 9c 00 00 01 00 00 00 01 00 00 00 | ....@...........
0xa94c9878: ef cd 1c a1 78 56 34 12 d0 d4 00 80 13 17 00 00 | ....xV4.........
0xa94c9888: 23 01 1c a1 e0 16 00 00 00 00 00 00 00 00 00 00 | #...............
0xa94c9898: 78 96 f9 aa f8 b0 4c a9 aa 58 25 08 78 56 34 12 | x.....L..X%.xV4.
0xa94c98a8: 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 | ................
0xa94c98b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94c98c8: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 40 00 | ..............@.
0xa94c98d8: 19 08 00 00 f0 af 4c a9 28 b0 4c a9 00 00 00 00 | ......L.(.L.....
0xa94c98e8: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa94c98f8: 48 16 48 16 40 99 4c a9 0c 00 00 00 40 99 4c a9 | H.H.@.L.....@.L.
malloc_header:0xa94c9888
M-size : 0x16e0
M-allocd : 0x082558aa
Region #22 [0xae2f5038] from #0 tback F0 dump off 0x00000050
0xae2f5018: 23 01 1c a1 18 00 00 00 00 00 00 00 00 00 00 00 | #...............
0xae2f5028: 30 71 a9 ad 20 ee 2f ae 37 87 67 08 31 06 07 08 | 0q.. ./.7.g.1...
0xae2f5038: 16 68 73 00 02 00 00 00 40 9b 30 a9 80 9a 30 a9 | .hs.....@.0...0.
0xae2f5048: 40 9a 30 a9 00 9a 30 a9 ef cd 1c a1 00 00 00 00 | @.0...0.........
0xae2f5058: d0 d4 00 80 ab 00 00 00 23 01 1c a1 7c 00 00 00 | ........#...|...
0xae2f5068: 00 00 00 00 00 00 00 00 50 51 2f ae 98 4a 2f ae | ........PQ/..J/.
0xae2f5078: 9b 14 a9 08 78 00 00 00 7d 1c 00 00 00 00 00 00 | ....x...}.......
0xae2f5088: 75 d8 20 01 07 00 00 00 00 00 00 00 00 00 00 00 | u. .............
0xae2f5098: 00 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 | ................
0xae2f50a8: fd 00 00 00 d8 5a 2e ae d8 48 2f ae 8b 1c fa 00 | .....Z...H/.....
Region #23 [UK:0xa5df5d2c] from #0 tback F0 dump off 0x00000054
0xa5df5d0c: a0 f4 08 00 45 00 00 3c 7b b2 00 00 80 01 66 7b | ....E..<{.....f{
0xa5df5d1c: c8 4c b2 cb bd a9 1f d2 00 00 82 49 28 08 ab 85 | .L.........I(...
0xa5df5d2c: 28 08 ab 85 34 60 e3 72 40 61 50 f8 9b e0 21 c4 | (...4`.r@aP...!.
0xa5df5d3c: 2a 84 67 de 4d 04 b5 f4 2d e0 b8 00 7b 3f 79 4d | *.g.M...-...{?yM
0xa5df5d4c: 74 00 00 01 00 01 00 04 cc 2e 2b a3 c0 0c 00 01 | t.........+.....
0xa5df5d5c: 00 01 00 00 45 0b 00 04 cc 2e 2b a4 c0 0c 00 01 | ....E.....+.....
0xa5df5d6c: 00 01 00 00 45 0b 00 04 cc 2e 2b a5 c0 0c 00 01 | ....E.....+.....
0xa5df5d7c: 00 01 00 00 45 0b 00 04 cc 2e 2b a6 c0 0c 00 01 | ....E.....+.....
0xa5df5d8c: 00 01 00 00 45 0b 00 04 cc 2e 2b a7 c0 0c 00 01 | ....E.....+.....
0xa5df5d9c: 00 01 00 00 45 0b 00 04 cc 2e 2b a8 c0 0c 00 01 | ....E.....+.....
Region #25 [0xa90a4b20] from #0 tback F0 dump off 0x0000005c
0xa90a4b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4b10: 00 00 00 00 00 00 00 00 58 3b 10 a9 00 00 00 00 | ........X;......
0xa90a4b20: 20 b3 04 a9 cc cc bb bb 67 ff 01 00 04 4e 0a a9 | .......g....N..
0xa90a4b30: 9c 4e 0a a9 d0 6e 58 08 8d 67 33 00 00 00 00 00 | .N...nX..g3.....
0xa90a4b40: 00 00 00 00 30 39 05 08 20 1f 59 0b 00 00 00 00 | ....09.. .Y.....
0xa90a4b50: 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff | ................
0xa90a4b60: 00 00 00 00 00 00 00 00 00 c0 00 00 98 4e 0a a9 | .............N..
0xa90a4b70: 98 4e 0a a9 98 4e 0a a9 98 4e 0a a9 d0 9c cd a5 | .N...N...N......
0xa90a4b80: b8 9c cd a5 00 ff ff 00 00 00 00 00 00 00 00 00 | ................
0xa90a4b90: 00 00 00 00 00 00 00 00 c0 00 2c 01 60 4c 0a a9 | ..........,.`L..
Block : 0xa90a4b20
B-base : 0xa90a4e04
B-size : 152
B-rptr : 0xa90a4e98
B-hptr : 0xa90a4e98
B-freed : 0x00000000
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #26 [0xa90a4bc0] ext-dump 0 of (Block) from #25
0xa90a4ba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4bb0: 00 00 00 00 ff ff ff ff 00 00 00 00 00 00 00 00 | ................
0xa90a4bc0: 00 00 00 00 00 00 00 00 00 00 00 00 88 00 00 00 | ................
0xa90a4bd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4be0: e9 25 07 00 00 00 00 00 00 00 00 00 00 00 00 00 | .%..............
0xa90a4bf0: 00 00 00 00 98 4e 0a a9 00 00 00 00 00 00 00 00 | .....N..........
0xa90a4c00: 00 00 00 00 00 00 00 00 6a fb 41 68 00 00 00 00 | ........j.Ah....
0xa90a4c10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #27 [0xa90a4e98] ext-dump 1 of (Block) from #25
0xa90a4e78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4e88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4e98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4ea8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4eb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4ec8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4ed8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4ee8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90a4ef8: 00 00 00 00 58 3b 10 a9 00 00 00 00 00 00 00 00 | ....X;..........
0xa90a4f08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #28 [UK:0xa5df5d48] from #0 tback F0 dump off 0x00000060
0xa5df5d28: 28 08 ab 85 28 08 ab 85 34 60 e3 72 40 61 50 f8 | (...(...4`.r@aP.
0xa5df5d38: 9b e0 21 c4 2a 84 67 de 4d 04 b5 f4 2d e0 b8 00 | ..!.*.g.M...-...
0xa5df5d48: 7b 3f 79 4d 74 00 00 01 00 01 00 04 cc 2e 2b a3 | {?yMt.........+.
0xa5df5d58: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a4 | ........E.....+.
0xa5df5d68: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a5 | ........E.....+.
0xa5df5d78: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a6 | ........E.....+.
0xa5df5d88: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a7 | ........E.....+.
0xa5df5d98: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a8 | ........E.....+.
0xa5df5da8: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b a9 | ........E.....+.
0xa5df5db8: c0 0c 00 01 00 01 00 00 45 0b 00 04 cc 2e 2b aa | ........E.....+.
Region #33 [0xcab24cc8] from #0 tback F0 dump off 0x0000007c
0xcab24ca8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24cb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24cc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24cd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24ce8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24cf8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24d08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24d18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24d28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xcab24d38: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #34 [0xa954f508] from tback F1
0xa954f4e8: 08 f5 54 a9 fa ed 8a 09 3e df 58 9a 75 9a 6b 00 | ..T.....>.X.u.k.
0xa954f4f8: 00 00 00 00 38 f5 54 a9 34 f5 54 a9 3c 45 e5 a9 | ....8.T.4.T.<E..
0xa954f508: 48 f5 54 a9 73 8f 67 08 58 c7 20 a9 34 f5 54 a9 | H.T.s.g.X. .4.T.
0xa954f518: 00 00 00 00 78 56 34 12 78 56 34 12 78 56 34 12 | ....xV4.xV4.xV4.
0xa954f528: 38 45 e5 a9 78 56 34 12 ea b8 35 00 00 00 00 00 | 8E..xV4...5.....
0xa954f538: 02 00 00 00 08 f2 1c a9 c8 ef ff ff 00 00 00 00 | ................
0xa954f548: 18 f6 54 a9 5c a2 06 08 38 ae ea 0a 78 56 34 12 | ..T.\...8...xV4.
0xa954f558: 78 56 34 12 78 56 34 12 00 00 00 00 08 f2 1c a9 | xV4.xV4.........
0xa954f568: c8 ef ff ff 00 00 00 00 18 f6 54 a9 50 f5 54 a9 | ..........T.P.T.
0xa954f578: 49 a2 06 08 78 56 34 12 78 56 34 12 78 56 34 12 | I...xV4.xV4.xV4.
Region #35 [0xa954b600] from #34 (malloc_header) magic off 0
M-size : 0x4000
Region #36 [0xa954f548] from #34 tback F1 dump off 0x00000000
0xa954f588: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f598: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f5a8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f5b8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
Region #37 [0xa954b600] from #36 (malloc_header) magic off 0
M-size : 0x4000
Region #38 [TX:0x08678f70] from #34 tback F1 dump off 0x00000004
0x08678f50: 02 75 ea 90 8d 74 26 00 eb 1e 8d b6 00 00 00 00 | .u...t&.........
0x08678f60: 8b 40 48 80 e4 3f 80 cc 40 89 42 48 89 d0 e8 8d | .@H..?..@.BH....
0x08678f70: e8 ff ff e8 58 33 9f ff 8b 55 08 8b 42 04 89 04 | ....X3...U..B...
0x08678f80: 24 e8 6a 5c 9e ff 85 c0 89 c2 75 d4 eb af c7 04 | $.j\......u.....
0x08678f90: 24 80 1f 00 00 e8 36 5e 23 01 85 c0 89 c3 89 45 | $.....6^#......E
0x08678fa0: e0 0f 84 27 01 00 00 8d 78 04 c7 40 24 e9 03 00 | ...'....x..@$...
0x08678fb0: 00 c7 40 14 ff ff ff ff c7 00 00 00 00 00 89 78 | ..@............x
0x08678fc0: 04 89 78 08 c7 40 0c 00 00 00 00 c7 40 10 00 00 | ..x..@......@...
0x08678fd0: 00 00 c7 40 18 10 4d 25 08 c7 40 1c 20 4d 25 08 | ...@..M%..@. M%.
0x08678fe0: 89 43 20 b8 01 00 00 00 83 c0 01 83 f8 0a 75 f8 | .C ...........u.
Region #39 [0xa920c758] from #34 tback F1 dump off 0x00000008
0xa920c738: d7 b5 af 09 30 e7 05 08 f4 87 d4 0a 00 00 00 00 | ....0...........
0xa920c748: 00 00 00 00 d7 b5 af 09 02 00 00 00 00 00 00 00 | ................
0xa920c758: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa920c768: 2d 29 04 00 08 c7 20 a9 d0 c7 20 a9 6c c7 20 a9 | -).... ... .l. .
0xa920c778: 80 1e 59 0b 08 13 21 a9 08 13 21 a9 20 c7 20 a9 | ..Y...!...!. . .
0xa920c788: e8 c7 20 a9 7c c7 20 a9 c0 c0 89 0b 7c 00 01 00 | .. .|. .....|...
0xa920c798: 01 00 00 00 60 ed ac 09 30 e7 05 08 f4 87 d4 0a | ....`...0.......
0xa920c7a8: 00 00 00 00 00 00 00 00 60 ed ac 09 02 00 00 00 | ........`.......
0xa920c7b8: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa920c7c8: 00 00 00 00 00 00 00 00 6c c7 20 a9 34 c8 20 a9 | ........l. .4. .
Region #40 [0xa920b770] from #39 (malloc_header) magic off 0
0xa920b750: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa920b760: 00 00 00 ef cd 1c a1 00 d0 d4 00 80 23 15 00 00 | ............#...
0xa920b770: 23 01 1c a1 f3 14 00 00 00 00 00 00 00 00 00 00 | #...............
0xa920b780: 90 54 1d a9 90 cc 20 a9 f3 c3 85 09 00 00 00 00 | .T.... .........
0xa920b790: 45 36 27 18 90 b7 20 a9 b8 cc 20 a9 00 00 00 00 | E6'... ... .....
0xa920b7a0: 00 00 00 00 00 00 00 00 00 00 00 00 9d c9 a3 15 | ................
0xa920b7b0: 32 00 00 00 32 00 00 00 64 00 00 00 64 00 00 00 | 2...2...d...d...
0xa920b7c0: 18 00 00 00 1a 00 00 00 1b 00 00 00 18 00 00 00 | ................
0xa920b7d0: 00 00 00 00 00 00 00 00 00 00 08 00 01 00 00 00 | ................
0xa920b7e0: 2f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | /...............
malloc_header:0xa920b770
M-size : 0x14f3
M-allocd : 0x0985c3f3
Region #41 [0xa920b798] from #39 (chunk-hdr) magic off 20
0xa920b778: 00 00 00 00 00 00 00 00 90 54 1d a9 90 cc 20 a9 | .........T.... .
0xa920b788: f3 c3 85 09 00 00 00 00 45 36 27 18 90 b7 20 a9 | ........E6'... .
0xa920b798: b8 cc 20 a9 00 00 00 00 00 00 00 00 00 00 00 00 | .. .............
0xa920b7a8: 00 00 00 00 9d c9 a3 15 32 00 00 00 32 00 00 00 | ........2...2...
0xa920b7b8: 64 00 00 00 64 00 00 00 18 00 00 00 1a 00 00 00 | d...d...........
0xa920b7c8: 1b 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa920b7d8: 00 00 08 00 01 00 00 00 2f 00 00 00 00 00 00 00 | ......../.......
0xa920b7e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa920b7f8: 57 61 74 63 68 65 64 20 51 75 65 75 65 00 00 00 | Watched Queue...
0xa920b808: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
chunk_type: 0xa920b798
C-base : 0xa920b8f8
C-size : 0x1388
C-type : 47
C-headtail: 0x00000000
Region #45 [0xa9e54538] from #34 tback F1 dump off 0x00000020
0xa9e54518: 23 01 1c a1 80 1f 00 00 00 00 00 00 00 00 00 00 | #...............
0xa9e54528: 00 92 bb a9 b0 e6 44 a9 9a 8f 67 08 00 00 00 00 | ......D...g.....
0xa9e54538: 00 00 00 00 80 45 e5 a9 b0 64 e5 a9 00 00 00 00 | .....E...d......
0xa9e54548: e7 03 00 00 ff ff ff ff 10 4d 25 08 20 4d 25 08 | .........M%. M%.
0xa9e54558: 38 45 e5 a9 e9 03 00 00 01 00 00 00 01 00 00 00 | 8E..............
0xa9e54568: ff ff 1f 00 16 00 00 00 00 00 00 00 75 dc da 5f | ............u.._
0xa9e54578: 38 50 2f ae 0b b4 d9 36 88 45 e5 a9 7a e4 48 79 | 8P/....6.E..z.Hy
0xa9e54588: 90 45 e5 a9 98 f2 c8 4b 98 45 e5 a9 f0 ca 09 38 | .E.....K.E.....8
0xa9e54598: a0 45 e5 a9 d6 06 67 7f a8 45 e5 a9 56 4d 77 42 | .E....g.E..VMwB
0xa9e545a8: b0 45 e5 a9 44 a0 a6 0e b8 45 e5 a9 2c 25 5f 3a | .E..D....E..,%_:
Region #48 [0xa91cf208] from #34 tback F1 dump off 0x00000034
0xa91cf1e8: 38 4f 7a ae 00 00 00 00 00 00 00 00 00 00 00 00 | 8Oz.............
0xa91cf1f8: 00 00 00 00 00 00 00 00 e4 ef 1c a9 00 00 00 00 | ................
0xa91cf208: 38 3e 1c a9 c8 26 59 0b 56 34 12 ff e4 ef 1c a9 | 8>...&Y.V4......
0xa91cf218: c8 26 59 0b 80 06 85 0a 00 00 00 00 c6 ff 31 09 | .&Y...........1.
0xa91cf228: 1c ff 33 a5 a8 ed 54 a9 00 00 00 00 c8 ef ff ff | ..3...T.........
0xa91cf238: 20 38 43 0b e0 8e 67 08 38 ae ea 0a 20 b6 54 a9 | 8C...g.8... .T.
0xa91cf248: 00 40 00 00 9a cc 52 7a c5 9d 6b 00 14 eb f4 93 | .@....Rz..k.....
0xa91cf258: 03 00 00 00 70 e3 03 00 00 00 00 00 00 00 00 00 | ....p...........
0xa91cf268: 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 | ................
0xa91cf278: 00 00 00 00 82 14 02 00 00 00 00 00 00 00 00 00 | ................
Region #49 [0xa91a6728] from #48 (malloc_header) magic off 0
0xa91a6708: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa91a6718: ef cd 1c a1 00 00 00 00 d0 d4 00 80 6b ed 02 00 | ............k...
0xa91a6728: 23 01 1c a1 38 ed 02 00 00 00 00 00 00 00 00 00 | #...8...........
0xa91a6738: 00 00 00 00 40 a7 1d a9 b4 a3 06 08 00 00 00 00 | ....@...........
0xa91a6748: 8c 7a 1a a9 20 86 1b a9 56 34 12 ff 00 00 00 00 | .z.. ...V4......
0xa91a6758: 0c a2 e1 0a 18 2f 30 ae 48 67 1a a9 00 a2 06 08 | ...../0.Hg......
0xa91a6768: 64 45 c5 b0 30 46 c5 b0 48 67 1a a9 c8 ef ff ff | dE..0F..Hg......
0xa91a6778: 00 00 00 00 40 44 d1 08 02 00 00 00 38 06 c5 b0 | ....@D......8...
0xa91a6788: 00 40 00 00 46 db ee eb ef 69 6b 00 98 89 02 00 | .@..F....ik.....
0xa91a6798: 00 00 00 00 08 49 85 00 00 00 00 00 00 00 00 00 | .....I..........
malloc_header:0xa91a6728
M-size : 0x2ed38
M-allocd : 0x0806a3b4
Region #50 [UK:0xffffefc8] from #34 tback F1 dump off 0x00000038
0xffffefa8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xffffefb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xffffefc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xffffefd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xffffefe8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xffffeff8: 00 00 00 00 00 00 00 00 | ........
Region #51 [0xa954f548] from tback F2
Region #52 [0xa954b600] from #51 (malloc_header) magic off 0
M-size : 0x4000
Region #53 [0xa954f618] from #51 tback F2 dump off 0x00000000
0xa954f5f8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f608: 78 56 34 12 00 00 00 00 00 00 00 00 00 00 00 00 | xV4.............
0xa954f618: 00 00 00 00 00 00 00 00 ef cd 1c a1 00 00 00 00 | ................
0xa954f628: d0 d4 00 80 b3 00 00 00 23 01 1c a1 84 00 00 00 | ........#.......
0xa954f638: 00 00 00 00 00 00 00 00 28 a2 51 a9 88 c2 56 a9 | ........(.Q...V.
0xa954f648: 3c f3 05 08 00 00 00 00 00 00 00 00 ed fe ad de | <...............
0xa954f658: a8 f6 54 a9 2c 18 21 a9 b8 c2 56 a9 58 a2 51 a9 | ..T.,.!...V.X.Q.
0xa954f668: 58 f6 54 a9 c0 c0 89 0b 42 00 01 00 03 00 00 00 | X.T.....B.......
0xa954f678: 80 06 85 0a 30 e7 05 08 f4 87 d4 0a 00 00 00 00 | ....0...........
0xa954f688: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #54 [0xa954b600] from #53 (malloc_header) magic off 0
M-size : 0x4000
Region #55 [TX:0x0806a25c] from #51 tback F2 dump off 0x00000004
0x0806a23c: 85 4c ff ff ff 89 04 24 e8 0f 0b 15 01 89 45 f4 | .L.....$......E.
0x0806a24c: 8b 45 f4 85 c0 75 4c 8b 43 38 89 04 24 ff 53 34 | .E...uL.C8..$.S4
0x0806a25c: 8b 45 f4 85 c0 75 15 65 8b 16 85 d2 74 0e 8b 82 | .E...u.e....t...
0x0806a26c: bc 00 00 00 8b 00 89 82 bc 00 00 00 8b 45 f4 83 | .............E..
0x0806a27c: e8 01 74 56 65 8b 06 c7 40 70 08 00 00 00 c6 80 | ..tVe...@p......
0x0806a28c: c1 00 00 00 01 89 40 18 8d 74 26 00 e8 cb 42 fe | ......@..t&...B.
0x0806a29c: ff eb f9 65 8b 06 c7 45 f4 02 00 00 00 c7 40 70 | ...e...E......@p
0x0806a2ac: 08 00 00 00 c6 80 c1 00 00 00 01 89 40 18 8d b6 | ............@...
0x0806a2bc: 00 00 00 00 e8 a3 42 fe ff eb f9 c7 85 48 ff ff | ......B......H..
0x0806a2cc: ff 00 00 00 00 e9 65 ff ff ff 8b 45 ec 89 44 24 | ......e....E..D$
Region #56 [ID:0x0aeaae38] from #51 tback F2 dump off 0x00000008
0x0aeaae18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0aeaae28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0aeaae38: 08 f2 1c a9 08 c7 20 a9 38 45 e5 a9 00 00 00 00 | ...... .8E......
0x0aeaae48: 01 00 00 00 01 00 00 00 d0 87 4c a9 00 00 00 00 | ..........L.....
0x0aeaae58: 00 00 00 00 00 00 00 00 0a 00 00 00 00 00 00 00 | ................
0x0aeaae68: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0aeaae78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0aeaae88: 17 00 00 00 ce 06 00 00 38 00 00 00 38 00 00 00 | ........8...8...
0x0aeaae98: 00 00 00 00 4e 48 ee b1 56 48 ee b1 00 00 00 00 | ....NH..VH......
0x0aeaaea8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #60 [0xa91cf208] from #51 tback F2 dump off 0x0000001c
Region #61 [0xa91a6728] from #60 (malloc_header) magic off 0
M-size : 0x2ed38
Region #62 [UK:0xffffefc8] from #51 tback F2 dump off 0x00000020
Region #63 [0xa954f618] from #51 tback F2 dump off 0x00000028
Region #64 [0xa954b600] from #63 (malloc_header) magic off 0
M-size : 0x4000
Region #65 [0xa954f550] from #51 tback F2 dump off 0x0000002c
0xa954f530: ea b8 35 00 00 00 00 00 02 00 00 00 08 f2 1c a9 | ..5.............
0xa954f540: c8 ef ff ff 00 00 00 00 18 f6 54 a9 5c a2 06 08 | ..........T.\...
0xa954f550: 38 ae ea 0a 78 56 34 12 78 56 34 12 78 56 34 12 | 8...xV4.xV4.xV4.
0xa954f560: 00 00 00 00 08 f2 1c a9 c8 ef ff ff 00 00 00 00 | ................
0xa954f570: 18 f6 54 a9 50 f5 54 a9 49 a2 06 08 78 56 34 12 | ..T.P.T.I...xV4.
0xa954f580: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f590: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f5a0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f5b0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa954f5c0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
Region #66 [0xa954b600] from #65 (malloc_header) magic off 0
M-size : 0x4000
Region #67 [TX:0x0806a248] from #51 tback F2 dump off 0x00000030
0x0806a228: 31 d2 39 c8 0f 45 d0 89 95 48 ff ff ff 89 8b bc | 1.9..E...H......
0x0806a238: 00 00 00 8d 85 4c ff ff ff 89 04 24 e8 0f 0b 15 | .....L.....$....
0x0806a248: 01 89 45 f4 8b 45 f4 85 c0 75 4c 8b 43 38 89 04 | ..E..E...uL.C8..
0x0806a258: 24 ff 53 34 8b 45 f4 85 c0 75 15 65 8b 16 85 d2 | $.S4.E...u.e....
0x0806a268: 74 0e 8b 82 bc 00 00 00 8b 00 89 82 bc 00 00 00 | t...............
0x0806a278: 8b 45 f4 83 e8 01 74 56 65 8b 06 c7 40 70 08 00 | .E....tVe...@p..
0x0806a288: 00 00 c6 80 c1 00 00 00 01 89 40 18 8d 74 26 00 | ..........@..t&.
0x0806a298: e8 cb 42 fe ff eb f9 65 8b 06 c7 45 f4 02 00 00 | ..B....e...E....
0x0806a2a8: 00 c7 40 70 08 00 00 00 c6 80 c1 00 00 00 01 89 | ..@p............
0x0806a2b8: 40 18 8d b6 00 00 00 00 e8 a3 42 fe ff eb f9 c7 | @.........B.....
Region #87 [0xa954f618] from tback F3
Region #88 [0xa954b600] from #87 (malloc_header) magic off 0
M-size : 0x4000
Region #94 [0xa951a228] from #87 tback F3 dump off 0x00000028
0xa951a208: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa951a218: ef cd 1c a1 00 00 00 00 d0 d4 00 80 b3 00 00 00 | ................
0xa951a228: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00 | #...............
0xa951a238: 48 86 50 a9 30 f6 54 a9 3c f3 05 08 00 00 00 00 | H.P.0.T.<.......
0xa951a248: 00 00 00 00 ed fe ad de a0 a2 51 a9 04 fa 1c a9 | ..........Q.....
0xa951a258: 60 f6 54 a9 78 86 50 a9 50 a2 51 a9 c0 c0 89 0b | `.T.x.P.P.Q.....
0xa951a268: 3f 00 01 00 02 00 00 00 ac ff 9c 09 30 e7 05 08 | ?...........0...
0xa951a278: f4 87 d4 0a 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa951a288: 60 c4 e2 0a 00 00 00 00 00 00 00 00 00 00 00 00 | `...............
0xa951a298: 00 00 00 00 00 00 00 00 04 fa 1c a9 00 00 00 00 | ................
malloc_header:0xa951a228
M-size : 0x84
M-allocd : 0x0805f33c
**WARNING: ptr 0xa951a228 not within (mh + 1) 0xa951a248 and (unsigned char *)(mh + 1) + mh->mh_len 0xa951a2cc
Region #95 [0xa9510ad0] from #94 (free_header) magic off 0
0xa9510ab0: 2e 64 61 74 00 00 00 00 ef cd 1c a1 00 00 00 00 | .dat............
0xa9510ac0: d0 d4 00 80 19 00 00 00 38 f4 e4 a9 30 4a d3 a9 | ........8...0J..
0xa9510ad0: 23 01 ee f3 ef cd ee f3 18 00 00 00 da 06 00 00 | #...............
0xa9510ae0: 23 01 1c a1 a8 06 00 00 00 00 00 00 00 00 00 00 | #...............
0xa9510af0: 50 18 4b a9 d0 ae bb a9 e6 a2 c9 08 00 00 00 00 | P.K.............
0xa9510b00: a8 5f 88 ad 88 35 51 a9 40 46 5b ad c0 a7 4d a9 | ._...5Q.@F[...M.
0xa9510b10: d8 35 51 a9 78 92 5b ad 00 00 00 00 00 00 00 00 | .5Q.x.[.........
0xa9510b20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9510b30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9510b40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
free_header:0xa9510ad0
MC-size : 0x19
MC-pre_siz: 0x8000d4d0
Region #96 [0xa956c288] from #87 tback F3 dump off 0x0000002c
0xa956c268: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa956c278: ef cd 1c a1 00 00 00 00 d0 d4 00 80 b3 00 00 00 | ................
0xa956c288: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00 | #...............
0xa956c298: 30 f6 54 a9 78 0a 58 a9 3c f3 05 08 00 00 00 00 | 0.T.x.X.<.......
0xa956c2a8: 00 00 00 00 ed fe ad de 00 c3 56 a9 9c e4 1c a9 | ..........V.....
0xa956c2b8: 08 cb 20 a9 60 f6 54 a9 b0 c2 56 a9 c0 c0 89 0b | .. .`.T...V.....
0xa956c2c8: 49 00 01 00 02 00 00 00 d6 11 b9 09 30 e7 05 08 | I...........0...
0xa956c2d8: f4 87 d4 0a 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa956c2e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa956c2f8: 00 00 00 00 00 00 00 00 9c e4 1c a9 00 00 00 00 | ................
malloc_header:0xa956c288
M-size : 0x84
**WARNING: ptr 0xa956c288 not within (mh + 1) 0xa956c2a8 and (unsigned char *)(mh + 1) + mh->mh_len 0xa956c32c
Region #97 [0xa9568238] from #96 (free_header) magic off 0
0xa9568218: 4c 10 52 00 00 00 00 00 ef cd 1c a1 60 e1 79 0b | L.R.........`.y.
0xa9568228: d0 d4 00 80 29 00 00 00 c0 8f d5 a9 a8 f3 4a ad | ....).........J.
0xa9568238: 23 01 ee f3 00 00 00 00 01 00 00 00 00 00 00 00 | #...............
0xa9568248: 10 32 e3 5e ef cd ee f3 28 00 00 00 32 40 00 00 | .2.^....(...2@..
0xa9568258: 23 01 1c a1 00 40 00 00 00 00 00 00 00 00 00 00 | #....@..........
0xa9568268: 00 b6 54 a9 48 ca 57 a9 b1 a7 06 08 00 00 00 00 | ..T.H.W.........
0xa9568278: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9568288: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9568298: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa95682a8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
free_header:0xa9568238
MC-size : 0x29
Region #98 [0xa9567f18] from #96 (chunk-hdr) magic off 20
0xa9567ef8: 00 00 00 00 00 00 00 00 e0 82 db a9 e0 e4 56 ad | ..............V.
0xa9567f08: f3 c3 85 09 d6 ba 06 08 45 36 27 18 10 7f 56 a9 | ........E6'..V.
0xa9567f18: b0 ad 50 a9 00 00 00 00 00 00 00 00 00 00 00 00 | ..P.............
0xa9567f28: 00 00 00 00 9d c9 a3 15 08 00 00 00 08 00 00 00 | ................
0xa9567f38: 28 00 00 00 28 00 00 00 08 00 00 00 00 00 00 00 | (...(...........
0xa9567f48: 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9567f58: 00 00 08 00 01 00 00 00 63 00 00 00 00 00 00 00 | ........c.......
0xa9567f68: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9567f78: 6e 61 74 20 63 68 75 6e 6b 00 00 00 00 00 00 00 | nat chunk.......
0xa9567f88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
chunk_type: 0xa9567f18
C-base : 0xa9567fd0
C-size : 0x140
C-type : 99
**WARNING: ptr 0xa956c288 not within chunk->data 0xa9567fd0 and chunk->end 0xa9568110
Region #99 [TX:0x0805f33c] from #87 tback F3 dump off 0x00000030
0x0805f31c: 00 00 00 00 55 89 e5 56 53 83 ec 10 c7 44 24 04 | ....U..VS....D$.
0x0805f32c: 84 00 00 00 c7 04 24 01 00 00 00 e8 f4 fa 84 01 | ......$.........
0x0805f33c: 85 c0 89 c3 74 6b c7 40 04 ed fe ad de 8d 70 08 | ....tk.@......p.
0x0805f34c: c7 80 80 00 00 00 ff ff ff 0f c7 40 7c ff ff ff | ...........@|...
0x0805f35c: 0f 8b 45 08 c7 44 24 0c 08 00 00 00 c7 44 24 08 | ..E..D$......D$.
0x0805f36c: 00 00 00 00 89 34 24 89 44 24 04 e8 24 14 80 01 | .....4$.D$..$...
0x0805f37c: 85 c0 74 36 c7 44 24 04 30 e7 05 08 89 04 24 e8 | ..t6.D$.0.....$.
0x0805f38c: b0 10 80 01 8b 43 30 8d 53 48 89 54 24 08 8d 53 | .....C0.SH.T$..S
0x0805f39c: 58 89 54 24 04 89 34 24 ff 10 c7 43 6c 80 1d 59 | X.T$..4$...Cl..Y
0x0805f3ac: 0b 83 c4 10 89 d8 5b 5e 5d c3 89 1c 24 31 db e8 | ......[^]...$1..
Region #101 [0xa954f6a8] from #87 tback F3 dump off 0x00000040
0xa954f698: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f6a8: 98 f3 1c a9 00 00 00 00 98 f6 54 a9 58 f6 54 a9 | ..........T.X.T.
0xa954f6b8: 00 00 00 00 80 1d 59 0b 00 00 00 00 00 00 00 00 | ......Y.........
0xa954f6c8: 00 00 00 00 ff ff ff 0f ff ff ff 0f ef cd 1c a1 | ................
0xa954f6d8: d0 d4 00 80 63 00 00 00 23 01 1c a1 30 00 00 00 | ....c...#...0...
0xa954f6e8: 00 00 00 00 00 00 00 00 d8 a2 51 a9 38 c3 56 a9 | ..........Q.8.V.
0xa954f6f8: 7a 28 8a 09 00 00 00 00 00 00 00 00 00 00 00 00 | z(..............
0xa954f708: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f718: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #102 [0xa954f630] from #101 (malloc_header) magic off 0
0xa954f610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f620: ef cd 1c a1 00 00 00 00 d0 d4 00 80 b3 00 00 00 | ................
0xa954f630: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00 | #...............
0xa954f640: 28 a2 51 a9 88 c2 56 a9 3c f3 05 08 00 00 00 00 | (.Q...V.<.......
0xa954f650: 00 00 00 00 ed fe ad de a8 f6 54 a9 2c 18 21 a9 | ..........T.,.!.
0xa954f660: b8 c2 56 a9 58 a2 51 a9 58 f6 54 a9 c0 c0 89 0b | ..V.X.Q.X.T.....
0xa954f670: 42 00 01 00 03 00 00 00 80 06 85 0a 30 e7 05 08 | B...........0...
0xa954f680: f4 87 d4 0a 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f690: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa954f6a0: 00 00 00 00 00 00 00 00 98 f3 1c a9 00 00 00 00 | ................
malloc_header:0xa954f630
M-size : 0x84
Region #103 [0xa921182c] from #87 tback F3 dump off 0x00000044
0xa921180c: f0 ca 20 a9 00 00 00 00 00 00 00 00 00 00 00 00 | .. .............
0xa921181c: 00 00 00 00 00 00 00 00 1c 18 21 a9 18 c7 20 a9 | ..........!... .
0xa921182c: 00 00 00 00 98 f3 1c a9 1c 18 21 a9 58 f6 54 a9 | ..........!.X.T.
0xa921183c: 08 f2 1c a9 08 c7 20 a9 00 00 00 00 00 00 00 00 | ...... .........
0xa921184c: 00 00 00 00 00 00 00 00 00 00 00 00 50 18 21 a9 | ............P.!.
0xa921185c: c8 cb 20 a9 00 00 00 00 a8 40 1d a9 50 18 21 a9 | .. ......@..P.!.
0xa921186c: a0 a8 45 a9 18 3f 1d a9 b8 cb 20 a9 00 00 00 00 | ..E..?.... .....
0xa921187c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa921188c: 84 18 21 a9 d4 c9 20 a9 00 00 00 00 38 49 1d a9 | ..!... .....8I..
0xa921189c: 84 18 21 a9 88 c3 36 a9 a8 47 1d a9 c4 c9 20 a9 | ..!...6..G.... .
Region #104 [0xa92106a0] from #103 (chunk-hdr) magic off 20
chunk_type: 0xa92106a0
C-base : 0xa9210878
C-size : 0x1040
C-type : 51
Region #105 [0xa956c2b8] from #87 tback F3 dump off 0x00000048
0xa956c308: f0 c2 56 a9 b0 c2 56 a9 00 00 00 00 80 1d 59 0b | ..V...V.......Y.
0xa956c318: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff 0f | ................
0xa956c328: ff ff ff 0f ef cd 1c a1 d0 d4 00 80 63 00 00 00 | ............c...
Region #106 [0xa951a258] from #87 tback F3 dump off 0x0000004c
0xa951a2a8: 90 a2 51 a9 50 a2 51 a9 00 00 00 00 80 1d 59 0b | ..Q.P.Q.......Y.
0xa951a2b8: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff 0f | ................
0xa951a2c8: ff ff ff 0f ef cd 1c a1 d0 d4 00 80 63 00 00 00 | ............c...
Region #107 [0xa954f658] from #87 tback F3 dump off 0x00000050
Region #108 [ID:0x0b89c0c0] from #87 tback F3 dump off 0x00000054
0x0b89c0a0: 60 4d 18 a9 00 00 00 00 00 00 00 00 00 00 00 00 | `M..............
0x0b89c0b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0b89c0c0: 88 1e 59 0b 40 6f 7a ae 00 00 00 00 00 00 00 00 | ..Y.@oz.........
0x0b89c0d0: 00 00 00 00 00 00 00 00 00 00 01 00 64 02 00 00 | ............d...
0x0b89c0e0: 19 76 be 09 30 04 86 09 f4 87 d4 0a 00 00 00 00 | .v..0...........
0x0b89c0f0: a8 27 20 a9 00 00 00 00 00 00 00 00 00 00 00 00 | .' .............
0x0b89c100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0b89c110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0b89c120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0b89c130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #110 [UD:0x0a850680] from #87 tback F3 dump off 0x00000060
0x0a850660: 1d da b5 09 cd b2 af 09 71 ef af 09 e1 8a 96 09 | ........q.......
0x0a850670: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0a850680: 49 4b 45 20 52 65 63 65 69 76 65 72 00 00 00 00 | IKE Receiver....
0x0a850690: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0a8506a0: 00 00 00 00 f4 01 00 00 01 00 00 00 f4 01 00 00 | ................
0x0a8506b0: 00 00 00 00 94 11 00 00 01 00 00 00 94 11 00 00 | ................
0x0a8506c0: 49 4b 45 20 54 69 6d 65 6b 65 65 70 65 72 00 00 | IKE Timekeeper..
0x0a8506d0: 43 69 73 63 6f 20 53 79 73 74 65 6d 73 2c 20 49 | Cisco Systems, I
0x0a8506e0: 6e 63 00 00 01 00 00 00 00 00 00 00 00 00 00 00 | nc..............
0x0a8506f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #111 [TX:0x0805e730] from #87 tback F3 dump off 0x00000064
0x0805e710: 09 89 44 24 14 8b 45 14 89 44 24 0c 8b 45 10 89 | ..D$..E..D$..E..
0x0805e720: 44 24 08 e8 d8 1f 87 01 b8 01 00 00 00 c9 c3 90 | D$..............
0x0805e730: 55 31 c0 89 e5 83 ec 18 8b 55 0c 85 d2 74 40 8b | U1.......U...t@.
0x0805e740: 42 08 39 d0 74 42 8b 40 24 8b 40 44 c7 44 24 10 | B.9.tB.@$.@D.D$.
0x0805e750: e4 65 95 09 89 44 24 14 8b 45 14 89 44 24 0c 8b | .e...D$..E..D$..
0x0805e760: 45 10 c7 44 24 04 ff 00 00 00 c7 04 24 9d 65 95 | E..D$.......$.e.
0x0805e770: 09 89 44 24 08 e8 86 1f 87 01 b8 01 00 00 00 c9 | ..D$............
0x0805e780: c3 8d b4 26 00 00 00 00 8b 40 20 ba 1d da b5 09 | ...&.....@ .....
0x0805e790: 85 c0 74 03 8b 50 14 89 54 24 14 c7 44 24 10 d8 | ..t..P..T$..D$..
0x0805e7a0: 65 95 09 8b 45 14 89 44 24 0c 8b 45 10 c7 44 24 | e...E..D$..E..D$
Region #112 [UD:0x0ad487f4] from #87 tback F3 dump off 0x00000068
0x0ad487d4: 10 27 00 00 10 27 00 00 10 27 00 00 f4 01 00 00 | .'...'...'......
0x0ad487e4: 50 c3 00 00 f4 01 00 00 88 13 00 00 05 00 00 00 | P...............
0x0ad487f4: f0 0d 86 09 10 0c 86 09 f0 0a 86 09 10 10 86 09 | ................
0x0ad48804: d0 09 86 09 e0 0e 86 09 ba 46 75 0a c4 46 75 0a | .........Fu..Fu.
0x0ad48814: 01 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0ad48824: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0ad48834: 00 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0ad48844: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 | ................
0x0ad48854: 00 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 | ....<...........
0x0ad48864: 00 00 00 00 55 86 75 0a 24 00 00 00 e8 ee 49 ad | ....U.u.$.....I.
Region #114 [0xa9e54538] from %ebx
Region #115 [0xa9e54580] from #114 (%ebx) dump off 0x00000004
0xa9e54560: 01 00 00 00 01 00 00 00 ff ff 1f 00 16 00 00 00 | ................
0xa9e54570: 00 00 00 00 75 dc da 5f 38 50 2f ae 0b b4 d9 36 | ....u.._8P/....6
0xa9e54580: 88 45 e5 a9 7a e4 48 79 90 45 e5 a9 98 f2 c8 4b | .E..z.Hy.E.....K
0xa9e54590: 98 45 e5 a9 f0 ca 09 38 a0 45 e5 a9 d6 06 67 7f | .E.....8.E....g
0xa9e545a0: a8 45 e5 a9 56 4d 77 42 b0 45 e5 a9 44 a0 a6 0e | .E..VMwB.E..D...
0xa9e545b0: b8 45 e5 a9 2c 25 5f 3a c0 45 e5 a9 62 ba a4 05 | .E..,%_:.E..b...
0xa9e545c0: c8 45 e5 a9 f2 67 b9 21 d0 45 e5 a9 b0 7c 8f 72 | .E...g.!.E...|.r
0xa9e545d0: d8 45 e5 a9 28 e7 35 1f e0 45 e5 a9 ae 1a 18 69 | .E..(.5..E.....i
0xa9e545e0: e8 45 e5 a9 4e 90 f8 67 f0 45 e5 a9 dc b3 e7 2c | .E..N..g.E.....,
0xa9e545f0: f8 45 e5 a9 e4 cc 9c 2f 00 46 e5 a9 ba 33 4f 2a | .E...../.F...3O*
Region #116 [0xa9e564b0] from #114 (%ebx) dump off 0x00000008
0xa9e56490: 98 64 e5 a9 10 4c 63 2c a0 64 e5 a9 76 c1 9a 4d | .d...Lc,.d..v..M
0xa9e564a0: a8 64 e5 a9 76 83 1a 49 b0 64 e5 a9 e4 6b 62 19 | .d..v..I.d...kb.
0xa9e564b0: 3c 45 e5 a9 4c 98 1f 22 ef cd 1c a1 00 00 00 00 | <E..L.."........
0xa9e564c0: d0 d4 00 80 6b 00 00 00 23 01 1c a1 38 00 00 00 | ....k...#...8...
0xa9e564d0: 00 00 00 00 00 00 00 00 30 62 b8 a9 18 a8 34 a9 | ........0b....4.
0xa9e564e0: 0b 8c 99 08 00 00 00 00 40 66 e5 a9 10 f0 e7 a9 | ........@f......
0xa9e564f0: c0 f0 e7 a9 70 f1 e7 a9 20 f2 e7 a9 00 00 00 00 | ....p... .......
0xa9e56500: fc 64 e5 a9 00 00 00 00 04 65 e5 a9 24 89 1c a9 | .d.......e..$...
0xa9e56510: 30 d3 1b a9 00 00 00 00 00 00 00 00 90 65 e5 a9 | 0............e..
0xa9e56520: ef cd 1c a1 00 00 00 00 d0 d4 00 80 3b 00 00 00 | ............;...
Region #119 [TX:0x08254d10] from #114 (%ebx) dump off 0x00000018
0x08254cf0: 74 24 04 e8 48 d7 64 01 8b 55 cc 65 8b 02 89 b0 | t$..H.d..U.e....
0x08254d00: b8 01 00 00 e9 06 fd ff ff 83 47 28 01 eb c9 90 | ..........G(....
0x08254d10: 55 89 e5 5d c3 8d 74 26 00 8d bc 27 00 00 00 00 | U..]..t&...'....
0x08254d20: 55 89 e5 5d e9 e7 a1 65 01 90 90 90 90 90 90 90 | U..]...e........
0x08254d30: 55 89 e5 8b 45 08 8b 55 0c 8d 04 80 0f b7 04 85 | U...E..U........
0x08254d40: c8 cd e2 0a c1 e2 02 03 55 10 5d 8b 44 10 0c c3 | ........U.].D...
0x08254d50: 55 89 e5 53 83 ec 14 8b 45 08 8b 4d 10 83 f8 04 | U..S....E..M....
0x08254d60: 77 70 8d 04 80 8d 14 85 c0 cd e2 0a 80 7a 0c 00 | wp...........z..
0x08254d70: 74 2e 0f b6 42 0d 3b 45 0c 75 73 66 39 4a 08 74 | t...B.;E.usf9J.t
0x08254d80: 46 c7 44 24 08 6f 02 00 00 c7 44 24 04 0a e1 9d | F.D$.o....D$....
Region #120 [TX:0x08254d20] from #114 (%ebx) dump off 0x0000001c
0x08254d90: 09 c7 04 24 dc f2 9d 09 e8 c3 8e 66 01 8d 76 00 | ...$.......f..v.
Region #121 [0xa9e54538] from #114 (%ebx) dump off 0x00000020
Region #126 [0xae2f5038] from #114 (%ebx) dump off 0x00000040
Region #128 [0xa9e54588] from #114 (%ebx) dump off 0x00000048
0xa9e545b8: c0 45 e5 a9 62 ba a4 05 c8 45 e5 a9 f2 67 b9 21 | .E..b....E...g.!
0xa9e545c8: d0 45 e5 a9 b0 7c 8f 72 d8 45 e5 a9 28 e7 35 1f | .E...|.r.E..(.5.
0xa9e545d8: e0 45 e5 a9 ae 1a 18 69 e8 45 e5 a9 4e 90 f8 67 | .E.....i.E..N..g
0xa9e545e8: f0 45 e5 a9 dc b3 e7 2c f8 45 e5 a9 e4 cc 9c 2f | .E.....,.E...../
0xa9e545f8: 00 46 e5 a9 ba 33 4f 2a 08 46 e5 a9 6a e2 57 61 | .F...3O*.F..j.Wa
Region #130 [0xa9e54590] from #114 (%ebx) dump off 0x00000050
0xa9e54600: 08 46 e5 a9 6a e2 57 61 10 46 e5 a9 c8 31 2a 03 | .F..j.Wa.F...1*.
Region #132 [0xa9e54598] from #114 (%ebx) dump off 0x00000058
0xa9e54608: 10 46 e5 a9 c8 31 2a 03 18 46 e5 a9 60 52 d2 7c | .F...1*..F..`R.|
Region #134 [0xa9e545a0] from #114 (%ebx) dump off 0x00000060
0xa9e54610: 18 46 e5 a9 60 52 d2 7c 20 46 e5 a9 86 d1 ac 12 | .F..`R.| F......
Region #136 [0xa9e545a8] from #114 (%ebx) dump off 0x00000068
0xa9e54618: 20 46 e5 a9 86 d1 ac 12 28 46 e5 a9 46 3a 10 2f | F......(F..F:./
Region #138 [0xa9e545b0] from #114 (%ebx) dump off 0x00000070
0xa9e54620: 28 46 e5 a9 46 3a 10 2f 30 46 e5 a9 74 a2 94 15 | (F..F:./0F..t...
Region #140 [0xa9e545b8] from #114 (%ebx) dump off 0x00000078
0xa9e54628: 30 46 e5 a9 74 a2 94 15 38 46 e5 a9 9c b3 80 13 | 0F..t...8F......
Region #144 [0xa9062b20] from #0 deep dump off 0x00000020
Block : 0xa9062b20
B-base : 0xa9062e04
B-size : 152
B-rptr : 0xa9062e98
B-hptr : 0xa9062e98
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #145 [0xa9062bc0] ext-dump 0 of (Block) from #144
Region #146 [0xa9062e98] ext-dump 1 of (Block) from #144
Region #148 [UK:0x09afb550] from #0 deep dump off 0x0000002c
Region #149 [UK:0x09aed844] from #0 deep dump off 0x00000030
Region #151 [0xa954f40c] from #0 deep dump off 0x00000038
Region #152 [0xa954b600] from #151 (malloc_header) magic off 0
M-size : 0x4000
Region #157 [0xa92106a0] from #0 deep dump off 0x00000050
Region #159 [TX:0x08678370] from #0 deep dump off 0x0000005c
Region #162 [0xa94ca7f0] from #0 deep dump off 0x0000006c
Region #163 [0xa94c9888] from #162 (malloc_header) magic off 0
M-size : 0x16e0
Region #164 [0xae2f5038] from #0 deep dump off 0x00000070
Region #166 [0xa90a4b20] from #0 deep dump off 0x0000007c
Block : 0xa90a4b20
B-base : 0xa90a4e04
B-size : 152
B-rptr : 0xa90a4e98
B-hptr : 0xa90a4e98
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #167 [0xa90a4bc0] ext-dump 0 of (Block) from #166
Region #168 [0xa90a4e98] ext-dump 1 of (Block) from #166
Region #169 [UK:0xa5df5d48] from #0 deep dump off 0x00000080
Region #174 [0xcab24cc8] from #0 deep dump off 0x0000009c
Region #184 [0xa95161f8] from #1 deep dump off 0x00000030
0xa95161d8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa95161e8: ef cd 1c a1 00 00 00 00 d0 d4 00 80 33 40 00 00 | ............3@..
0xa95161f8: 23 01 1c a1 00 40 00 00 00 00 00 00 00 00 00 00 | #....@..........
0xa9516208: 18 46 50 a9 00 b6 54 a9 b1 a7 06 08 00 00 00 00 | .FP...T.........
0xa9516218: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9516228: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9516238: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9516248: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9516258: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa9516268: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
malloc_header:0xa95161f8
M-size : 0x4000
**WARNING: ptr 0xa95161f8 not within (mh + 1) 0xa9516218 and (unsigned char *)(mh + 1) + mh->mh_len 0xa951a218
Region #185 [0xa9510ad0] from #184 (free_header) magic off 0
MC-size : 0x19
Region #186 [0xa9568258] from #1 deep dump off 0x00000034
0xa95682b8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
0xa95682c8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12 | xV4.xV4.xV4.xV4.
malloc_header:0xa9568258
M-size : 0x4000
**WARNING: ptr 0xa9568258 not within (mh + 1) 0xa9568278 and (unsigned char *)(mh + 1) + mh->mh_len 0xa956c278
Region #187 [0xa9567f18] from #186 (chunk-hdr) magic off 20
C-base : 0xa9567fd0
C-size : 0x140
C-type : 99
**WARNING: ptr 0xa9568258 not within chunk->data 0xa9567fd0 and chunk->end 0xa9568110
Region #188 [TX:0x0806a7b0] from #1 deep dump off 0x00000038
0x0806a790: b8 00 40 00 00 0f 45 d8 8b 3d 0c a2 e1 0a 85 ff | ..@...E..=......
0x0806a7a0: 89 7d e4 0f 84 13 04 00 00 89 1c 24 e8 bf 93 00 | .}.........$....
0x0806a7b0: 00 85 c0 89 45 e8 0f 84 19 04 00 00 8b 45 08 89 | ....E........E..
0x0806a7c0: 04 24 e8 59 4b ff ff 85 c0 89 45 ec 0f 84 59 04 | .$.YK.....E...Y.
0x0806a7d0: 00 00 8b 35 14 a2 e1 0a 85 f6 74 5b c7 45 f0 00 | ...5......t[.E..
0x0806a7e0: 00 00 00 eb 16 8d 76 00 8b 86 20 02 00 00 85 c0 | ......v... .....
0x0806a7f0: 0f 84 91 03 00 00 89 75 f0 89 c6 8b 4d 08 89 4c | .......u....M..L
0x0806a800: 24 04 8b 46 14 89 04 24 e8 d3 ae 84 01 85 c0 79 | $..F...$.......y
0x0806a810: d7 8b 45 f0 85 c0 0f 84 87 03 00 00 8b 45 e4 89 | ..E..........E..
0x0806a820: b0 20 02 00 00 8b 55 f0 89 82 20 02 00 00 a1 14 | . ....U... .....
Region #213 [0xa9103b58] from #2 deep dump off 0x00000018
0xa9103b38: 00 00 00 00 00 00 00 00 00 00 00 00 90 54 1d a9 | .............T..
0xa9103b48: ae c1 85 09 00 00 00 00 45 36 27 18 50 3b 10 a9 | ........E6'.P;..
0xa9103b58: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9103b68: 00 00 00 00 9d c9 a3 15 00 04 00 00 00 04 00 00 | ................
0xa9103b78: c0 03 00 00 00 04 00 00 d1 00 00 00 2f 03 00 00 | ............/...
0xa9103b88: 2f 03 00 00 d1 00 00 00 40 00 00 00 00 00 00 00 | /.......@.......
0xa9103b98: 40 00 50 00 45 02 00 00 42 02 00 00 00 00 00 00 | @.P.E...B.......
0xa9103ba8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9103bb8: 4c 6f 63 61 6c 20 62 6c 6f 63 6b 00 00 00 00 00 | Local block.....
0xa9103bc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #214 [0xa9057f20] from #2 deep dump off 0x00000020
0xa9057f00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9057f10: 00 00 00 00 00 00 00 00 58 3b 10 a9 00 00 00 00 | ........X;......
0xa9057f20: 20 a3 0a a9 cc cc bb bb 67 ff 01 00 04 82 05 a9 | .......g.......
0xa9057f30: 9c 82 05 a9 97 8c 29 08 a6 01 45 00 00 00 00 00 | ......)...E.....
0xa9057f40: 00 00 00 00 30 39 05 08 20 1f 59 0b 00 00 00 00 | ....09.. .Y.....
0xa9057f50: 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff | ................
0xa9057f60: 00 00 00 00 00 00 00 00 00 c0 00 00 98 82 05 a9 | ................
0xa9057f70: 98 82 05 a9 98 82 05 a9 98 82 05 a9 90 bd e3 a5 | ................
0xa9057f80: 78 bd e3 a5 00 00 00 00 00 00 00 00 00 00 00 00 | x...............
0xa9057f90: 00 00 00 00 00 00 00 00 c0 00 2c 01 60 80 05 a9 | ..........,.`...
Block : 0xa9057f20
B-base : 0xa9058204
B-size : 152
B-rptr : 0xa9058298
B-hptr : 0xa9058298
B-allocd : 0x08298c97
B-location: 0x00000088
B-meta : 0x0
B-flags2 : 0x0
B-input :
B-output :
Region #215 [0xa9057fc0] ext-dump 0 of (Block) from #214
0xa9057fa0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9057fb0: 00 00 00 00 ff ff ff ff 00 00 00 00 00 00 00 00 | ................
0xa9057fc0: 00 00 00 00 00 00 00 00 00 00 00 00 88 00 00 00 | ................
0xa9057fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9057fe0: 6e 4b 07 00 00 00 00 00 00 00 00 00 00 00 00 00 | nK..............
0xa9057ff0: 00 00 00 00 98 82 05 a9 00 00 00 00 00 00 00 00 | ................
0xa9058000: 00 00 00 00 00 00 00 00 b6 fa 46 68 00 00 00 00 | ..........Fh....
0xa9058010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9058020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9058030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #216 [0xa9058298] ext-dump 1 of (Block) from #214
0xa9058278: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9058288: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa9058298: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582a8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582d8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa90582f8: 00 00 00 00 58 3b 10 a9 00 00 00 00 00 00 00 00 | ....X;..........
0xa9058308: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
Region #217 [0xbbbbcccc] from #2 deep dump off 0x00000024
0xbbbbccac: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbccbc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbcccc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbccdc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbccec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbccfc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbcd0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbcd1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbcd2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xbbbbcd3c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
End of Selective memory dump
Traceback of previous thread 'Dispatch Unit':
0: 0x08298b79
1: 0x0806a25c
This crash dump matches another vulnerability which was reported in version 9.1.5.
https://tools.cisco.com/bugsearch/bug/CSCul36176/?reffering_site=dumpcr
Shivapramod M
Please remember to select a correct answer and rate helpful posts
So did the bug get fixed an reintroduced 700 times or is 9.1.7 just a very lucky version? It sounds like from below that not even 9.1.7 is fixed. Can we get some move useful information?
Randy, do you know if this exploit applies to site-to-site tunnels?  The docs I have read don't specify remote access or site-to-site (or both).  For site-to-site would an attacker have to spoof a valid peer address?  Thanks.
Hi Pete,
Yes, It does apply for Site-to-Site tunnels and remote users using IKEv1 or IKEv2 connections, the attack is based on IPSEC malformed packets, hence the attacker does not need to spoof a valid peer address, it takes advantage of the ASA listening on the IPSEC port (UDP 500)
More details about this attack:
https://blog.exodusintel.com/2016/02/10/firewall-hacking/
Hope it helps
-Randy-
Rate helpful post to help other users to find the answer quickly.
Is anyone aware of issues upgrading to 9.3(3.7)?
