CSCvv61753 - Management interface Gi0/0 randomly unreachable
Makoto. Y
I have a question.
Is this bug affected in 16.12.1 ?
Excerpt a quote from this bug description "CSCvv61753"...
> Known Affected Releases:(1)
>  16.12.4
Hi According to the bug report known affected version is 16.12.4. so 16.12.1 will not marked affected unless they do proper investigation.
you can try workaround or further problem description to investigate by yourself or open a TAC for in detailed cisco investigation.
Good luck
Rate this and mark as answer if this solved your concern
KB
Good luck
KB
Hi, I appreciate your answer.
I want to have a deeper understanding of command "platform management port sgmii
on "Further Problem Description" .
So can anyone give me the link to the command reference about this command ?
 > Further Problem Description:
 > This issue is fixed in 16.12.5. If the customer faces this problem, he needs to configure below " CLI" command.
 > "platform management port sgmii auto-neg disabled" in config mode.
