CSCvw95683 - Cat1000 freeze, unexpectedly silent reboot and crash issue occurred randomly
phrogg
I'm observing the same behavior with a C1000-24T-4X-L running on 15.2(7)E3k. Happens randomly, just recently after only 5 hours of uptime.
18 Replies 18
Leo Laohoo
I am not sure how "accurate" the details in the Bug ID are, but it says that versions affected are 15.2(7)E1 and 15.2(7)E2.  You're running a re-build, 15.2(7)E3k.
Can you try downgrading to 15.2(7)E3 and verify?
Sure, will give it a try. Then again, I'm not quite sure if downgrading from a rebuild like k helps (something to my understanding like a fix level version of x.x.11 for k), which I'm assuming contains several bug fixes within this very release.
You'll need to determine i15.2(7)E3 does keep it stable (until the fix is released).
Thank you for the hint. downgrading to 15.2(7)E3 indeed keeps the Cat1000 switch stable - at least so far, which would have crashed by now compared to the the k rebuild.
Give it a few more weeks.
Let us know how things go in, say, 8 weeks uptime.
phrogg
Will do. I did set a reminder to check and report back here
kenku
Hello Phrogg, may I know the current Status of 15.2(7) E3 ? Since almost 4 weeks past.  Million thanks .
Give him time.  4 weeks is "just" not enough to pass judgement.
Alternatively, tap internally and ask the developers to provide the pre-release version.
Everything is working smoothly with the 15(7) E3. No crashes or any trouble so far.
What is the uptime of the stack?
uptime is 4 weeks, 5 days, 8 hours, and 12 minutes
That's good to hear.
I would say another 4 weeks more should be a good indication if this version is stable or not.
So, coming back after another couple of weeks, I had a crash on one switch after approx. 7 weeks of uptime. The crash happened when I tried to access the web interface. It seems to me that crash is highly related to accessing the web interface. My conclusion for now is to shutdown the web UI.
Post the complete output to the following commands:
sh version
sh log on uptime
dir flash:
dir flash:core
Pray the crash left crashinfo or systeminfo files for us to analyze.
