CSCwd71093 - Problem with booting FMC after upgrading
fmpacisco
When upgrading from 7.2.5 to 7.2.7 this bug is also occurring.  I have two TAC cases open prior to finding the error message and this documented bug, so we'll see if I get a response.
5 Replies 5
balaji.bandi
Do you have a backup of FMC ?
is this virtual or Physical ?
what is the reason of upgrade ?
if this is virtual - i will build fresh FMC and try to restore and config and re-join FTD as quick fix.
BB
Yes.
Virtual.
Hitting other bugs.
Thanks.  I was debating on doing that if TAC didn't have a fix.  That will probably be easier than getting a response.
Much appreciated.
Matt
fmpacisco
Building a fresh 7.2.5 FMC, restoring it, and upgrading it to 7.2.7 failed also.  Building a new 7.2.7 and trying to restore a 7.2.5 config to it will not work as the FMC won't allow it being on different versions.
fmpacisco
Adding a serial port the VM prior to upgrading fixed this issue.  That was all.  It's not even in use.  It just wanted to be added.  Just FYI in case this helps someone some day in the future.
Thanks a lot! Faced the same issue with the update FMC KVM (Proxmox) from 7.0.6.2 to 7.2.7. Workaround with Serial port fixed it.
