08-29-2019 02:53 AM
Hello folks,
I tried to look at my configuration but nothing suspecting I found. I checked dial-peer, dial-plan everything is fine though csim start command is giving error. I did checked bug raised and there is similar I found / raised for v16.6.
CSCvb27784 Router crashes when running the csim start command
Router ISR4331 IOS does not get crashed but i get below response
"XXXXXXXXX#csim start 09920XXXXXX
csim: Test started.This command can only be run one at a time.
csim: called number = 09920XXXXXX, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(1024) minor(0x0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0"
sh dial-peer voice summary output
1009 pots up up 0.......... 0 up 0/1/0:15 NA
sh dialplan number 09920XXXXXX
VoiceEncapPeer1009
peer type = voice, system default peer = FALSE, information type = voice,
description = `###-Local Outbound-###',
tag = 1009, destination-pattern = `0..........',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 1009, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `',
connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
Destination route-string = None
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
type = pots, prefix = `',
forward-digits all
session-target = `', voice-port = `0/1/0:15',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 3, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "2F ",
Last Disconnect Text is "no resource (47)",
Last Setup Time = 259385.
Last Disconnect Time = 0.
Matched: 09920XXXXXX Digits: 1 Matched pattern: 0.......... Preference: 0
Target:
Any suggestion / help faced by someone and got addressed?
regards,
Ritesh Desai
03-28-2023 09:22 PM
CSIM command does not work on SSH sessions, you must login using Telnet and will work
