IN switches reboot with fatal error Reporting Task: HCLT.
Junak
BootROM 1.41
Booting from SPI flash
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
mvCtrlPexPolaritySet: TWSI Write skipped, leaving PEX polarity in EP mode
PEX: pexIdx 0, detected no link
DDR3 Training Sequence - Ver TIP-1.57.0
mvSysEnvGetTopologyUpdateInfo: skipped Twsi read to enable DDR ECC update
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
Msys Booton: Sep 7 2021 00:40:16 ver 3.1.6
Secure Boot: ON
Press x to choose XMODEM...
Booting from NAND flash
Secure Boot: Verify U-Boot secure imageSecure Boot: getBootonSecureHeader
image sha256: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Verify secure U-Boot (1-1) pass
Running UBOOT...
U-Boot 2013.01 (Feb 13 2023 - 01:10:46) Version: armada-17.06.6 V3.2.1.22
NAND ID = 0xDA01
NAND Model = Cypress/Spansion 2Gb 8bit S34ML02G2
EZ1K secure board
CBS350-24T-4G
FPGA Version: 34.25
uboot sha256 calculated by booton: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Loading active image ...
image sha256: 509DD7D7CB484E70F4E90351FBD768F1B489D4F90F971F2DF38ED5A83E82C6B9
[ 15.547409] I2C frequency 100 kHz (Tclk 200 MHz, freq_m 12, freq_n 3)
EZ1K A2 AIKIDO device
BOOTP ubi: Starting Boot...
MAC address : 58:56:9f:ec:9c:20.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Generating 256 bit AES encryption key
13-Feb-2023 01:09:06 %SYSLOG-F-OSFATAL: TAM API tam_lib_object_create failed TAM_LIB_ERR_PROCESS_FAIL
***** FATAL ERROR *****
Reporting Task: ROOT.
Software Version: (date time )
base_address=0x004f9000
ros(+0x7e0f30)[0xcd9f30]
ros(HOSTG_fatal_error+0x18)[0xcdd640]
ros(OSSYSG_fatal_error+0x244)[0x1225270]
ros(OSSYSG_fatal_error_formatted+0x44)[0x122541c]
ros(SSTORG_init+0x6d4)[0xcb1abc]
ros(HOSTL_set_rout_params+0x11c)[0xcad6b8]
ros(HOSTG_start+0x1a0)[0xcd4854]
/lib/libp2linux.so.1(task_run+0xf4)[0xb6ec2870]
/lib/libp2linux.so.1(sys_task_self_info+0xb0)[0xb6ec3948]
/lib/libp2linux.so.1(t_create_self+0x3c)[0xb6ec44c4]
ros(main+0x120)[0xca9070]
/lib/libc.so.6(__libc_start_main+0x110)[0xb698c680]
***** END OF FATAL ERROR *****
***************** SYSTEM RESET *****************
ROS exit
[ 65.924348] reboot: Restarting system
@Junak hi, looks like OS issue. try to upgrade to latest OS. if you have contract open a TAC case for further analysis and fix.
Good luck
KB
  - @Kasun Bandara   Poster has duplicated this bug : https://community.cisco.com/t5/switches-small-business/re-cisco-cbs350-prompt-console/td-p/5289614
                                             You may find my answer in there informative ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
