01-09-2021 10:54 PM
Hi all.
ISE version 2.7 under Work Centers>Posture>Settings>Software Updates>Posture Updates, "Automatically check for updates starting from initial delay" check box is checked with initial delay 01:00:00 every 1 Hours but no periodic updates.
I have to press on "Update Now" to get updates.
Any thoughts
Thanks in advance.
Solved! Go to Solution.
01-09-2021 11:46 PM
01-09-2021 11:07 PM
01-09-2021 11:24 PM
Hi Mohammed,thanks for your prompt response.
If i press the "Update Now" button the update starts and completes successfully.
But if i don't, no periodic updates takes place automatically every 1 hour after the initial delay as configured.
Check attached screenshot.
Thanks in advance
01-09-2021 11:46 PM
