ISE 2.7 periodic posture updates does not work
stsag_080067084
Hi all.
ISE version 2.7 under Work Centers>Posture>Settings>Software Updates>Posture Updates, "Automatically check for updates starting from initial delay" check box is checked with initial delay 01:00:00 every 1 Hours but no periodic updates.
I have to press on "Update Now" to get updates.
Any thoughts
Thanks in advance.
I think you are hitting a bug and the fix is listed in 3.0. See this link
below.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv80113/?rfs=iqvred
***** please remember to rate useful posts
Just to confirm, did you have an update and it wasn't applied?
stsag_080067084
Hi Mohammed,thanks for your prompt response.
If i press the "Update Now" button the update starts and completes successfully.
But if i don't, no periodic updates takes place automatically every 1 hour after the initial delay as configured.
Check attached screenshot.
Thanks in advance
below.
