09-29-2023 07:03 AM
Hi !
I have an issue on CISCO7609-S Version 12.2(33)SRC1.
Given this simple config :
int Te9/2.4000
encaps dot1q 4000
xconnect 10.10.10.10 10104000 encaps mpls
backup peer 10.10.10.11 10114000
backup delay 10 30
mtu 9100
When UP with primary peer, MTU is 9100 but when it switches to backup peer, MTU returns to default value 9216.
Did someone already notice that ? Is there any workaround ?
Thanks.
09-29-2023 07:11 AM
may be EOL decade back coming to your issue, what is the main interface MTU configured , i dont remember you can change sub-interface MTU ?
09-29-2023 07:29 AM
main interface MTU is 9216. Actually, here we modify MTU in the "xconnect" context (for compliance with remote peer).
It works with the primary peer, not with the backup peer..
So you guess it's an IOS software issue ? I performed research but found nothing about this..
As you can see with a "sho mpls l2transport vc int Te9/2.4000 detail", local MTU is 9216 in the backup section.
Local interface: Te9/2.4000 up, line protocol up, Eth VLAN 4000 up
MPLS VC type is Eth VLAN, interworking type is Ethernet
Destination address: 10.10.10.10, VC ID: 10104000, VC status: up
Output interface: Po1, imposed label stack {25947 524087}
Preferred path: not configured
Default path: active
Next hop: 10.20.20.20
Create time: 7w0d, last status change time: 2w2d
Signaling protocol: LDP, peer 10.10.10.10:0 up
Targeted Hello: 10.9.9.9(LDP Id) -> 10.10.10.10
Status TLV support (local/remote) : enabled/supported
Label/status state machine : established, LruRru
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: no fault
Last local SSS circuit status sent: no fault
Last local LDP TLV status sent: no fault
Last remote LDP TLV status rcvd: no fault
MPLS VC labels: local 2896, remote 524087
Group ID: local 0, remote 0
MTU: local 9100, remote 9100
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 8442091, send 19777721
byte totals: receive 2122750758, send 23155206728
packet drops: receive 0, seq error 0, send 0
Destination address: 10.10.10.11, VC ID: 10114000, VC status: down
Output interface: if-?(0), imposed label stack {}
Default path: no route
No adjacency
Signaling protocol: LDP, peer 10.10.10.11:0 up
Targeted Hello: 10.9.9.9(LDP Id) -> 10.10.10.11
Label/status state machine : remote invalid, LrdRrd
Last local SSS circuit status rcvd: DOWN(not-forwarding)
Last local SSS circuit status sent: AC DOWN(rx,tx faults), PW DOWN(rx,tx faults)(not-forwarding)
Last local LDP TLV status sent: DOWN(not-forwarding)
Last remote LDP TLV status rcvd: AC DOWN(rx,tx faults)(not-forwarding)
MPLS VC labels: local 4053, remote 130927
MTU: local 9216, remote 9100
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
09-29-2023 08:10 AM - edited 10-05-2023 07:03 AM
Then you guess an IOS software issue ?
