Not able to save configuration - N9k
dfreem12
copy running-config startup-config
[########################################] 100%
Configuration update aborted: request was aborted.
reload
!!!WARNING! there is unsaved configuration!!!
This command will reboot the system. (y/n)? [n]
Other chats say that startup is read-only and sup needs to be reloaded, can we reload just sup or the whole device?
There are a few bugs in which the behavior is the same but on different version and Nexus model. The workaround is always the same: reload.
 If I were you I would give it a try.
@dfreem12
 what is the N9K version? If this is related to the Bug CSCvk06919  , reload is the workaround.
 Actually it does not matter much if you reload the Sup or the device. They will be down time anyway.
9.3.7, but will be upgrading to 9.3.8, once able to copy config to startup.
