Not able to save configuration
rishad ahammed
I am working on N9K-C93240YC-FX2.  But I am not able to save the configuration in switch. Please find the below result.
[########################################] 100%
Configuration update aborted: request was aborted
Even I cannot upgrade the NX-OS. When I am trying to copy new NX-OS to bootflash it is giving error "file error
Destination: Read-only file system"
IS there any fix.
Hi, could be an issue related to this bug:
bootflash filesystem is mounted read only
CSCuz52346
Is not yet fixed but the workaround is "reload the supervisor".
Do you have already reload the supervisor? Make a configuration backup first.
what NX-OS is installed?
Regards.
CSCuz52346
Regards.
Thanks alot .. Its working
dfreem12
How did you reload the sup?
Jameel Ahmed
Just ran into a similar issue on a newly booted N3K switch and wanted to share the fix! I was getting errors saving the running config to startup. Checking the logs, I found the following message:
2025 Apr 17 22:00:55.315 C9K-SW13 %SECURITYD-2-INVALID_ADMIN_PASSWD: User admin has NULL password. Copy r s aborted
Turns out, I hadn't set the admin password yet. After setting a password for the 'admin' user, I was able to successfully save the configuration. Might be something to watch out for on fresh setups!
