Advice for a novice?
Rnh050864
Any advice for someone just getting started in networking? And i mean just getting started, I'm pondering a career change at 46 years old.
burleyman
Level 8
Level 8
I did the same thing almost 11 years ago. I was a machinist/Toolmaker from my early 20's til I was 41 and I made the leap.
If you are new then I would highly recommend studying for the NETWORK+ exam first, then after that start on the Cisco train. I would get the book Network+ for Dummies it was a very easy read and easy to understand....here is the link and you can get it for a penny plus shipping!
http://www.amazon.com/Networking-Dummies-Sixth-Doug-Lowe/dp/0764516779/ref=sr_1_3?ie=UTF8&qid=1326306493&sr=8-3
I would also get the new CCNA 640-802 Network Simulator (2nd Edition) I have it and it is great. While it is much better to have your own equipment and you can do that down the line, having this simulator would be a great first step. Here is a link to that.
http://www.amazon.com/CCNA-640-802-Network-Simulator-2nd/dp/1587204444/ref=sr_1_1?s=books&ie=UTF8&qid=1326306706&sr=1-1
Next if you have a community college close by see if they have a networking class that you can take or some even offer the CCNA course as a full semester class and if you can swing the money it would be well worth it.
I wish you good luck and you made a great first step in getting involved here.
Good luck.
Below is something that was an easy way I found to get subnetting it in my head, but you MUST also be able to do this by converting to binary as well..
In subnetting the only thing you really need to memorize is…..
Mask - 128….192….224….240….248….252….254….255
And remember the number 256
Learn that and everything else is easy…..
Now let’s learn how to find the number of IP addresses for a subnet mask or CIDR notation.
Let’s say you want to know how many IP address you have given a subnet mask.
Mask – 255.255.255.224
Take 224 and subtract that from 256…. So 256 – 224 is 32, so that means you have 32 IP addresses available for the mask of 255.255.255.224. Now to find the assignable addresses you subtract 2 (one for the broadcast address and one for the network address) so you have 30 assignable IP addresses. Simple right?
Now let’s say they give you this mask, /29, well here is where that little memorization comes in. So let’s convert that to dotted decimal…. 255.255.255.248
Take 248 and subtract that from 256….. So 256 – 248 is 8, so that means you have 8 IP addresses available for the mask of 255.255.255.248 or /29, which in turn means there are 6 assignable IP addresses after you subtract the broadcast and network IP addresses. Easy right?
Done right? No! What if you see something like this?
255.255.240.0…… Now what! Well we just have to do one more thing.
Let’s use that .240. 0 and pretend the .0 does not exist so just think .240, now from the above work figure out the number of IP addresses for .240 which we would get by subtracting that from 256, remember? So 256 – 240 is 16. Now here is the “one more thing” you need to do. Take that 16 and multiply it by 256 (we use 256 because we are one octet up). So 256*16 is 4,096, and there you have the number of IP address available for the mask of 255.255.240.0 and just subtract the broadcast and network addresses and you have 4,094 assignable IP addresses.
255.192.0.0……Now what! Well we just have to do two more things.
Let’s use that .192.0. 0 and pretend the .0.0 does not exist so just think .192, now from the above work, figure out the number of IP addresses for .192 which we would get by subtracting that from 256, remember? So 256 – 192 is 64. Now here is the “two more things” you need to do. First take 256*256 (we do 256 twice because we are 2 octets up) which is 65,536 now take 65,536 and multiply it by the 64. So 65,536*64 is 4,194,304, and there you have the number of IP address available for the mask of 255.192.0.0 and just subtract the broadcast and network addresses and you have 4,194,302 assignable IP addresses.
Done right? No! Last but not least, what if you see something like this?
248.0.0.0……Now what! Well we just have to do three more things.
For this we have to use 248.0.0.0 and then pretend the .0.0.0 does not exist so just think .248, now from the above work, figure out the number of IP addresses for .248 which we would get by subtracting that from 256, So 256 – 248 is 8. Now here is the “three more things” you need to do. First take 256*256 then take that result and multiply it by 256 (we do 256 three times because we are 3 octets up) which 256*256 is 65,536 now take 65,536 and multiply it by 256 and you get 16,777,216. Now you take 16,777,216 and multiply it by 8 from above and you get 134,217,728 and there you have the number of IP address available for the mask of 248.0.0.0 and just subtract the broadcast and network addresses and you have 134,217,728 assignable IP addresses.
Please say we are done now….my head hurts! Yes that should cover everything you need to find the number of IP addresses for a given mask. Now, thankfully you probably will not see any masks like the last example or the one previous either in real life or on any exams, at least not CCNA or CCNP. I gave those just to show how you can do it if someone decides to test your knowledge.
Now you say, well that is all well and good but what about wildcard masks! Easy I say!....well easy for “normal” wildcard masks. What you need to remember is wildcard masks are not just the inverse of subnet masks, they are and entity of their own.
For “normal” or inverse subnet masks just remember this, substitute all 255’s with 0’s and all 0’s with 255’s.
We will use the above four examples.
Example 1:
255.255.255.224 with 32 IP Addresses. To find the wildcard mask remember replace the 255’s with 0’s, now take the number of IP addresses and subtract 1 and place that where the 224 is. So you would get, 0.0.0.31, and there is your wildcard mask.
Example 2:
255.255.240.0 with 16 IP addresses. Remember substitute all 255’s with 0’s and all 0’s with 255’s so you have this 0.0.?.255 and the ? would be 16 – 1 which is 15. So you get a wildcard mask of 0.0.15.255, not bad right.
Example 3:
255.192.0.0 with 64 IP addresses. Now with the substitutions and subtract 1 from the IP addresses you get a wildcard mask of 0.63.255.255, you’re getting it, one more to go.
Example 4:
248.0.0.0 with 8 IP addresses. Again with the substitutions and subtract 1 from the IP addresses you get a wildcard mask of 7.255.255.255, now you got it, wildcard masking made easy.
Now, for the not so normal wildcard masks. Did you know this is a valid wildcard mask, 64.16.0.3
To look up more on these wildcard masks I found a good explanation at http://inetpro.org/wiki/wildcard_masks
Rnh050864
I haven't gotten to read your reply in detail, just that you DID reply and it looks like theres alot of great advice. I just wanted to thank you asap. I've been getting a little frustrated already with reading all the tales of woe about not being able to find work and with my being unsure of even how to start the process of getting an education at the ripe ol age of 46. So its great to get some positive advice. Il be checking back here later after work. Thanks again
Rob
There is work out there...it just depends on the area and what you are looking for.
Mike
Rob Huffman
Hey C.O.C.G - Mike,
Fantastic, helpful answer here my friend! +5 all day long
Cheers!
Huff
PS: Happy 2012
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
