2960x image transfer with Catalyst Center using HTTPS.
Omi+
Frequent Visitor
Frequent Visitor
Software Image transfer on 2960x using Catalyst Center with HTTPS does not work.
I get following error.
Failure (NCSW32001: Distribution failed using protocol: HTTPS. Distribution of image: c2960x-universalk9-tar.152-7.E11.tar on device. with protocol: HTTPS . Loading Image File to Device failed!. Device response error: [ Could not buffer tarfile...using multiple downloads examining image... %Error opening https://(DNAC IP)/api/v1/file/temporary/6ae95ab4-c09f-4f25-a825-f1198c507052 (I/O error) %Error opening flash:update/info (No such file or directory) ERROR: Image is not a valid IOS image archive. . ] )
Also followed guidelines mentioned in this article but no difference.
Troubleshoot HTTPS Error in Cisco Catalyst Center for SWIM - Cisco
is there any bug or compatibility issue with Classic IOS and Catalyst center (Version 2.3.7.7) ?
5 Replies 5
pieterh
this is not an error related to https!
https is ok, but the file could not be stored locally. -> first to check is free space in flash
maybe there are too many old images present in flash to download the new one?
or you did not select cleanup filesystem before download?
also check if you really want to upgrade using the .tar image or only need the .bin
the "multiple downloads" mechanism is also used without using Catalyst Center,when using a command like "archive download-image...." and there is not enough image to download the complete .tar archive.
2960X runs on classic IOS therefore the file should be a TAR file.
Omi+
Frequent Visitor
Frequent Visitor
It doesn't accept .bin file for stack upgrade. I have verified there are sufficient space in flash. Also deleted old images and tried, no change.
Remote into one of the switch stacks and post the complete output to the command "dir".
I suspect the issue is the previous "upgrade" was done with copy-the-BIN-file-to-all-switches method.
Omi+
Frequent Visitor
Frequent Visitor
Switch#dir
Directory of flash:/
2 -rwx 10664 Apr 15 2025 13:46:12 +00:00 vlan.dat
3 -rwx 510 Nov 11 2013 16:36:41 +00:00 express_setup.debug
4 -rwx 26774528 Apr 28 2022 01:54:51 +00:00 c2960x-universalk9-mz.152-7.E5.bin
6 -rwx 5491 Apr 30 2025 09:06:07 +00:00 private-config.text
7 -rwx 6525 May 6 2025 08:57:05 +00:00 bindings.txt
8 drwx 512 Jan 20 2000 04:48:52 +00:00 c2960x-universalk9-mz.150-2.EX3
587 drwx 512 Sep 22 2020 16:35:16 +00:00 dc_profile_dir
590 -rwx 643130 Apr 30 2025 09:05:57 +00:00 config.text
589 -rwx 5144 Apr 30 2025 09:06:08 +00:00 multiple-fs
122185728 bytes total (71472128 bytes free)
Switch#
