Add IP Pool In SDA Virtual Network: isIpDirectedBroadcast NOT working
Taniadv
Dear All,
Hope you are well.
For a customer of ours, we are using the API (/dna/intent/api/v1/business/sda/virtualnetwork/ippool) to add ip pools in SDA VNs. For one of the pool we would like to enable the IP Directed Broadcast and L2 Flooding. In the API I see an option for both (boolean). When set to true, the pools are created, L2 flooding is enabled, however IP Directed Broadcast remains disabled.
  • isIpDirectedBroadcast:boolean
  • isL2FloodingEnabled:boolean
 Perhaps I am missing something?
"fabricSiteNameHierarchy": "Global/XXX/YYY",
"virtualNetworkName": "EXAMPLE",
"ipPoolName": "EXAMPLE-POOL",
"trafficType": "Data",
"authenticationPolicyName": "EXAMPLE-POOL",
"isL2FloodingEnabled": true,
"isIpDirectedBroadcast": true
Thank you for your help.
I can confirm that this will be present in 2.2.2.6. Unfortunately, 2.2.2 APIs are not differentiated on developer.cisco.com, so it's difficult to tell when a particular API came. But yes, this is not present in 2.2.2.5, it should be there in the next build (2.2.2.6).
5 Replies 5
jalejand
Documentation might have changed, because the attribute "isIpDirectedBroadcast" is not under the VN Pool provisioning documentation for 2.1.2.7 and 2.2.2.3:
Which DNA Center version are you using? And, could you also provide the documentation you are using where the IPDirectedbroadcast attribute is set on? The POST call can include some unsupported values like "isWakeOnLan" without taking any effect.
Hi Jalejand,
Thank you for the information.
We are currently running DNAC version 2.2.2.5, and I got the information from here: https://developer.cisco.com/docs/dna-center/#!cisco-dna-center-2-2-2-sda-api-api-sda-add-ip-pool-in-sda-virtual-network
directed broadcast attribute is not implemented for IP pool addition (not as far as I am aware of). As always, I strongly recommend looking at documentation in the DNAC UI itself (under Platform -> Developer Toolkit), and not developer.cisco.com to confirm what is supported and what isn't (developer.cisco.com gets this wrong time and again).
Thank you Aninda.
