C9K switches
sallyonsy
Is 9K supported through DNA v1.3.1?
Tomas de Leon
Please check out the following URLs for continued device support:
SD-Access 1.x.x Hardware and Software Compatibility Matrix
https://www.cisco.com/c/en/us/solutions/enterprise-networks/software-defined-access/compatibility-matrix.html
Cisco DNA Center Supported Devices (XLSX - 74 KB)
https://www.cisco.com/c/en/us/support/cloud-systems-management/dna-center/products-device-support-tables-list.html
Release Notes - Cisco DNA Center, Release 1.3.x
https://www.cisco.com/c/en/us/support/cloud-systems-management/dna-center/products-release-notes-list.html
ChuckMcF
Short answer is yes. You can look up all supported models here: https://www.cisco.com/c/en/us/solutions/enterprise-networks/software-defined-access/compatibility-matrix.html
HTH,
ChuckMcF
