08-23-2024 09:19 AM
Question for all those who are provisioning network profiles and setting to their Cisco 9800 WLC from Cisco Catalyst Center.
How are you provisioning an SSID that requires a mDNS Service list provisioned at the same time? There does not seem to be a place to create the mdns Service List or how to link it to the SSID.
If I were to configure this manually on the 9800 wireless controller as part of a SSID, it is easy to do. You create your mDNS Service List under menu Configuration > Services > mDNS on the 9800 WLC. The in a policy profile for that SSID under the Advanced tab you can set the "mDNS Service Policy". Nice and Easy and documented nicely in the C9800 docs.
But I cannot find the equivalent in CCC. In CCC as part of the SSID Design in a SSID under the Advanced SSID Configuration there is a mDNS Mode feature in the miscellaneous menu but nowhere to build a custom mDNS service List or where to apply this to a SSID.
Solved! Go to Solution.
08-23-2024 11:01 AM
So I received some information about this post. It sounds like this is in early field trials. So hopefully included soon.
08-23-2024 11:01 AM
08-23-2024 07:09 PM
If I was to do something like this, I would knock up the commands in CLI.
And I manage 10 x 9800 and 8 x 8540 controllers.
08-25-2024 10:37 AM
That is exactly what I am about to do.
