Check Hardware Components for version mismatch
aforslund
Hello!
When running the validation tool for Appliance Infrastructure Status i get a critical message with the following:
Firmware version 4.3(2.240053) is not supported. RAID controller version 51.23.0-5009 is not supported
I just upgraded the CIMC firmware/bios using the HUU Tool, so it should be the latest firmware?
I am running Catalyst Center 2.3.7.6-70319 on an C220 M5.
Any way to resolve this?
Thanks!
shane.carnahan
You have to check the release notes for the version of Catalyst Center. According to the notes you are not running a tested/supported version for 2.3.7.6. Looks like Cisco IMC Version 4.3(2.240009) for appliance model DN2-HW-APL, DN2-HW-APL-L, DN2-HW-APL-XL since you referenced a c220 M5. It's very close but not exact to what I see in the notes.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/catalyst-center/2-3-7/release_notes/b_cisco_catalyst_center_237_release_notes.html#supported-firmware
Catalyst Center 2.3.7.5 and later has been validated only against the following firmware:
  • Cisco IMC Version 4.1(2m) for appliance model DN1-HW-APL
  • Cisco IMC Version 4.3(2.240009) for appliance model DN2-HW-APL, DN2-HW-APL-L, DN2-HW-APL-XL
  • Cisco IMC Version 4.3(2.230270) and 4.3(2.240009) for appliance model DN3-HW-APL, DN3-HW-APL-L, DN3-HW-APL-XL
shane.carnahan
Thank you Shane. You're right it's an DN2-HW-APL appliance. I was sure I read that document before upgrading, but not well enough as it seems.. Time for an downgrade then I guess.
