Cisco 9600 VSL links adding more in
patrickroberts
Hi All
Currently have a situation where an existing VSS setup with 9600 needs to have more VSL links ,currently only have 2 but now wanting 4.
To do this would it mean down time and a reboot as per below when you setup the links , or would you be able just to add more in without a reboot.
This is hard to test due to a live Core and not able to Lab this.
Device>enable
Device#configure terminal
Device(config)#interface FortyGigabitEthernet1/0/5
Device(config-if)#stackwise-virtual link 1
WARNING: All the extraneous configurations will be removed for FortyGigabitEthernet1/1/1 on reboot
INFO: Upon reboot, the config will be part of running config but not part of start up config.
Device(config-if)#end
Device#write memory
Device#reload
0 Replies 0
