We have experienced replacing the self-signed certificate of DNAC. We have found two issues while replacing the certificate. One problem we have fixed is that we have forgotten to add an intermediate certificate between the identity and root certificates from our CA.
But the second issue was the warning message while replacing is still not fixed. The warning message is about FQDN.
After login to maglev, cli found the cluster name is included, and in the identity certificate, the cluster name is included too. Every node's FQDN name is also included in the identity certificate and the PNP fqdn name because only the cluster name is included in the maglev. We are not sure if it is the root cause of it.
We would be grateful if someone could help find the problem.
Thanks in advance.
