Cisco DNA Center scp fails with wrong ip adress from dna center
Anders Joensson
Hello
i'v trying to uppgrade och wan access routers, cisco 891 anf cisco 891F and everything works but scp when DNA should copy the file to the router.
my DNA server has x.x.255.10 local address, but the error message says different se below
Unable to download file using HTTPs and SCP using IP : x.x.255.9
Expected : Device need to have https/scp reachability to Controller
Action : Verify HTTPS/SCP configurations, DNAC certificates on device and protocol reachability
we found the error, it was a typo error :)
/Anders
5 Replies 5
Anders Joensson
Problem solved !
What was the solution?
Often, this issue is caused by invalid DNAC certificate on the network device. You can remove and re-add the DNAC certificate onto the network device. Once this is completed, you can confirm the configuration and certificate is correct by executing the following command successfully from the network device:
-- copy https://<dnac-ip>/core/img/cisco-bridge.png flash:
I am having the same issue.  We changed the IP on a smaller DNA appliance and moved it to a DEV subnet for our testing lab.  I replaced the cert but still have issues with the File Transfer Check trying to use the old IP address.
I changed out the cert on the appliance and removed the DNAC certs the router we are testing with and still receive the error of the wrong IP.
Any suggestions.
