Cisco DNA Center
MHYA
Is it possible to run DNA center on other than DNA appliance for example on Hyper-V or ESXi.
8 Replies 8
nitekum5
No, DNA center is only available on the DN1-HW-APL (DNA Center appliance) by Cisco.
Why is the DNA center so slow using the following
devnetuser/Cisco123!
it is a turtle gives me great confidence as I move forward to use the product
Rickey369
No. You have to buy Appliance !!
Yes, You have to buy the DNAC appliance (Product ID -  DN1-HW-APL).
Roy Harrington
The image for DNA Center is an ISO so you can technically put it on ESXI. The CPU requirements are 22 + cores, however I have yet to try this in the lab.It may or may not work.
Right now DNAC is only officially supported by Cisco when it is running on the Cisco DNA appliance. The only way to get the DNAC ISO access is to purchase the appliance as the software is not publicly available at this time.There for if you have the image you should have the appliance, thus why not use the appliance instead of configuring something that Cisco will not help you with such as running DNAC in a hypervisor.
Hope this answered the question a bit more MHYA.
inderdeeps
Level 4
Level 4
Cisco DNA Center 2.1.2.0 is now available on the public release, Do anyone upgrade the DNAC 2.1.2.0 on production environment
Inderdeep
www.thenetworkdna.com
Mohamed Alhenawy
No, It's not possible current to deploy DNAC as virtual , so must be get the DN1-HW, but within near time Cisco will release the virtual.
MartinKajan
Not currently, but Cisco is already testing a virtual DNAC - for anyone interested in 2022.
