Bookmark
Subscribe
445
Cisco DNAC maglev wizard not working
PTA90
Hi everyone,
We are initializing dnac and want to change the managementment ip set before, when we access KVM to enter maglev winzard it does not show up and keeps flapping with error "ERROR: Post_Install is in process, cannot run winzard. Exiting..."
Please help me!
@PTA90
I can see on your first print that maglev restricted is active. Try to change this and see if you can run the Wizard
Disable Restricted Shell Temporarily
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-2/admin_guide/b_cisco_dna_center_admin_guide_2_3_2/b_cisco_dna_center_admin_guide_2_2_3_chapter_010.html
Torbjørn
It seems that the install isn't 100% completed yet. How long has it been running since you started the install? You will either have to wait for all post install tasks to complete(I usually let the DNAC run overnight) or reinstall it.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
