I'm having issues migrating maps with access point locations from Cisco Prime 3.10.1 and DNAC 2.2.3.6 using the Prime Data Migration Tool. The sync is successful between Prime and DNAC but when I look in DNAC for the the particular map I moved it shows a blank map and my access points are not positioned in DNAC. In Prime, the map and access point placements show up fine.
Any ideas on what the issue might be? I've attached a screenshot of a test floor map from DNAC.
