Cisco Prime - Customised wireless reporting
alex.de.gracia
Is it possible to focus reports based on a particular location or certain WLC?
We're a global organisation and i just want to run a lot of reports just based on my region/location or WLCs.
It seems difficult to find how to modify the reporting fields.
Alex
anantsiv
HI Alex,
That is possible , you can run reports on various WLC remotely as well . You will option option for modification is is reports--> report launch pad
Ananth
