DNA Center reset system
kj.stjernqvist
Is there a way to reset a DNA Center appliance to "factory defaults" ?
Gaur Samal
When you say “factory defaults” please note that , by default there is a pre-installed DNAC version installed.
As of now there is no reset/soft-reset option which can revert back to that relase.
Only option is to do fresh install via ISO ( you can choose which version you want to install and select respective ISO’s).
5 Replies 5
Gaur Samal
I only want to reset the database back to "null".
Is there a downloadable ISO on CCO ? I haven´t found it.
Please open up a TAC case, they will be able to publish you the ISO download link.
Ok, do you know if I can find the serial for the appliance via the DNA C Gui ?
For Failed Backup and Restore operation requires service cleanup (Reset). I would recommend to open a TAC Case.
