Cisco SG550X replacement - CBS350 port designation changed.
GavinH77
We are in the process of replacing our out of support SG550 switches with the recommended CBS350.  We have noted that the port designations differ, the SG550 has an up/down numbering scheme, where the CBS350 is horizontal assignment...1.....to 24, then 25 to 48 on the lower ports.
Is there a direct replacement for the Sg550 that would still have the up/down port layout??  I would like to de-risk the replacement and not have to change the config.
Thanks!!!
marce1000
 - No you can't  , as far as connections is concerned , perhaps it's good to be able to verify a connection (settings)  w.r.t the (new) port being used , (for instance - incorrect settings from  a previous port-connection could be discovered)
 M.
