compute requirement for catalyst centre VA
avdheshkumar
Hi All,
we are planning to deploy catalyst centre VA in our environment. can anyone suggest the compute requirement for the same. i Know the compute details are available for AWS instance. can we use the same for on prem deployments as well.
Avdhesh
balaji.bandi
Look at the installation guide :
https://www.cisco.com/c/en/us/support/cloud-systems-management/dna-center/products-installation-guides-list.html
Same virtual environment on prem, yes if you using Esxi look at the installation guide that guide you compute requirement.
By the are you looking to join both in HA environment ?
BB
avdheshkumar
Hi Balaji,
Thanks for the quick response, i was wondering if can we create HA between physical and virtual appliance.
