DNA Center 10GB SFP not working
lgd1
We have a 2nd generation DNA center appliance DN2-HW-APL-L which was connected with a 1GB SFP on the enterprise and cluster ports. We replaced the SFPs for a SFP-10G-SR-S and now such SFPs are not even showing lights on the LEDs, they have completely turned off.
Is there a way if the SFPs were detected correctly via the CIMC KVM console?
Is there a need to force the speed to 10Gb before deploying the new SFPs?
Any other suggestions are welcome!
Thank you.
Mark Elsen
  >...Is there a need to force the speed to 10Gb before deploying the new SFPs?
                 - I would at least try that (first)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce1000, thank you for your reply!
As far as we know, everything is set to auto, but it´s not clear to us how we can force the enterprise ports to 10GB. Any clue on the procedure?
Thanks!
  - The DNAC appliance is in essence an UCS server ; you should try to find out how to set fixed speed to 10G for connected SFP ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
