DNA Center and Meraki Dashboard
mjrduarte
I'm trying to integrate the Meraki Dashboard in DNA Center (2.3.5), but I'm running into some issues.
In the "Add Device" screen it asks for "API / Password" in the "HTTP(S)" section.
If I input the API here, I can get the Organization details, but if I click on Validate it gives the error "Invalid credentials for HTTP(S)"
If I add the device anyway, it starts syncing, but at the end it says "Partial Collection Failure" and in the device details says "Unreachable" and "Managed" with "Internal Error" underneath.
In the documentation it states "In the API Key/Password field, enter the API key and password credentials and click the Get Organization details link.", but I don't see where I can input the password credentials.
Am I missing something?
Thank you in advance for any help you can give me.
marce1000
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwi89896
 M.
7 Replies 7
marce1000
 M.
mjrduarte
Thank you for your help.
In the bug report it says that this problem is fixed on version 2.3.5.6, but this version is not yet available?
         - Then you need to engage TAC , on their bug report (Cisco) statements ,
 M.
mjrduarte
I will open a TAC case.
Thank you for your assistance.
 - Ok , no problem , perhaps you could give feedback on that (TAC case)  here too , always useful for others to know ,
 M.
mjrduarte
Once I get feedback from TAC, I'll update this thread.
mjrduarte
So, I just got back from TAC, and they applied a workaround, since the fixed version (2.3.5.6) is not yet published.
