DNA Center low impact mode contract
Stuart Patton
In DNA Center 2.3.3.7, I want to amend the ACL/contract that is the IPV4_PRE_AUTH_ACL for Low Impact mode to add another protocol/port.  When I click "Add Contract Action" I only get the option of bootpc, bootps or domain.  Are these options fixed?  This particular ACL/contract is not under policy -> group-based access control because it's nothing to do with SGT, so am I missing something here?
Incidentally, I'm trying to get an acceptable solution to allow PXE booting (and it's TFTP that I want to add to the ACL/contract) without resorting to no auth/open auth on the ports.  The reason this is needed is because normal dot1x timer on a closed mode port is too long - by the time the port has completed MAB the client has given up.
If anyone has alternative solutions, I'd be grateful.
Stuart
rahbhard
Hi Stuart,
That is correct, currently only the three protocols mentioned (67, 68, 53) are limited to amend on IPV4_PRE_AUTH_ACL for Low Impact mode. You can add custom ACEs to authentication ACL using Day-N templates.
Rahul Bhardwaj
rahbhard
Hi Stuart,
Rahul Bhardwaj
