DNAC and SSM satellite integration
LeroyW
I was wondering if there is integration support between DNA Center and an on-premise SSM satellite (similar to the option for e.g. IPAM or the more recently added option to add StealthWatch Management Center in the settings).
My understanding is that you have to either use DNAC directly or do it manually via CLI.
I don't see this option in the settings currently, but maybe there is a magctl/maglev command to configure the license-manager pod? If not, maybe someone can shed light on if this is a planned feature?
Mariusz Kazmierski
Currently there is no native DNAC /SSM integration. In case you want to use satellites for your devices, you can push through template editor satellite details for license registration.
Regards, Mariusz
Mariusz Kazmierski
Regards, Mariusz
