DNAC ip addresses
dijix1990
I configured DNAC with three interfaces:
Management - eno1 - 192.168.100.2/24 with VIP 192.168.100.1 - it's out of band network in my company
Enterprises - enp94s0f0 - 192.168.150.2/24 with VIP 192.168.150.1
Cluster - enp94s0f1 - 192.168.20.2/24 with VIP 192.168.20.1
I have 2 questions:
1. It's normal that DNAC goes to my devices in pool 192.168.100.0/24 via Management interface?
2. I thought that DNAC will go to devices via VIP addresses but it goes via non vip addresses because I added addresses 192.168.100.1 and 192.168.150.1 to my ACL and it isn't work until I add physical addresses 192.168.100.2 and 192.168.150.2
PabMar
DNAC interfaces work kinda like a router. It will get to the destination subnet over the interface that has a route to it.
If you've put a default route over the MGMT interface and there's no more specific static routes on the enterprise port, then it will go via the mgmt port.
Hope that helps.
Regards.
Ok, and what about VIP address? Why DNAC doesn't use VIP for cli and snmp access?
