10-15-2021 04:59 AM - edited 10-17-2021 11:45 PM
Hi all,
While executing the lan automation to onboard access switches. On one of the switches i am facing a weird issue which i dont have a clue to why DNAC is doing that.
During the lan automation process i am seing the following log message on the switch that is being discovered
Oct 15 11:41:13.624: %PNP-6-PNP_BACKOFF_NOW: PnP Backoff now for (169200) seconds requested (1/3) by (profile=pnp-zero-touch, ip=10.1.1.130, port=443)
From what i understand de DNAC (PNP server) is telling the switch (PNP agent) to rest for X amount of seconds and call back later. I normaly see this message with a range of 0-59 seconds. However this message is telling the switch to wait 169200 seconds which equals to 47 hours. I have restarted the Lan automation process several times without any success and the backoff time is always equal to 47 hours. Basically what this means is that the lan automation process for this switch will take more than 47 hours. Automation at its best :-). I can do it faster
Does anyone knows why this is happening and how to solve it?
TIA
09-07-2022 09:28 AM
You should check the plug & play section (Menu -> Provision -> Plug & Play). In my case the switch with this serial number was already registered there and after removing it from PnP the 169200 seconds backoff timer was gone after erasing the switch and restarting LAN automation.
07-23-2024 02:23 PM
Hi @EdwinPastoors
Thanks a lot. I have the same problem and fix it with this tips.
