DNAC layer 3 handoff with HA FTD
M. G.
Hi all,
I am trying to set up Layer 3 handoff between cisco border node on one side and pair of FTD in HA mode on the other. The problem is that DNAC uses /30 subnet for P2P connectivity and I need minimum 3 IPs to use ( 1 on switch and 2 for active/standby FTD). If I change subnet to /29 it is all good until I try to add another VN which results in DNA overriding the configuration and reconfigure the subnets back to /30.
Is there a way to configure DNAC to use /29 instead of /30 for these links?
usaf_27
This specific feature kept me from implementing SD-Access in which I made a wish on. It is now available in the 2.3.4.x version I believe.  It can now be customized.
Per the Release notes.
Custom Border Layer 3 Handoff IP Addressing”
PabMar
Why not make the switchports trunk and let the Borders and FTDs build the BGP neighbor relationship through those trunks?
Regards.
