DNAC login / cluster join issue
useridisblank
I'm attached to the DNAC via the CIMC KVM and I am prompted to enter my credentials.  I enter what was configured during setup, and I get an auth fail.  Attempting to join box #2 to the cluster results in an auth fail.  SSH to the box and I can login with the creds created at setup.  Has anyone else experienced this issue?
This is a clean installation of 1.3.1.4
Tala_Ali
This may be occur before you power-cycle the appliance.
Mohamed Alhenawy
Hello @useridisblank
Try to install with the same steps in the link below, also would like to draw your kind attention once you checkbox the cluster link option during the installation, the box #2 can access with the same credentials of box #1.
https://community.cisco.com/t5/networking-documents/cisco-dnac-deployment-from-zero/ta-p/3949407
