DNAC monitor/stop scheduled tasks
KevinMuller
Hello guys,
Quick question about DNA Center 1.3.1.5. Is there any possibility to have a view on the scheduled task (Provision, SWIM, ..) and maybe stop the schedule if required? Even a API call to perform this?
This look strange to not have this integrated to the GUI.
Thanks for your help,
Kevin
Aninda Chatterjee
Hey Kevin, this should be doable - top right corner in your DNAC GUI (next to the little globe). Scheduled tasks typically go here - you can edit/cancel as required.
Once you click on this, you should see something like the below image:
You can now edit/cancel as needed. I could only test this on a DNAC running 1.3.3.5 but this should be there on 1.3.1.5 as well.
Cheers,
Aninda
Aninda Chatterjee
Cheers,
Aninda
WOW, I completely missed this one!
Thanks a lot for your help!
Kevin
Hello Team,
I have similar issue but the only changes is TASK is already started and in progress, this TASK is scheduled for image distribution, but due to some network issue it was not happen. but TASK stuck in the middle even after distribution failed. now how to stop that TASK which is in progress
