DNAC -SWIM functionality and port 80
sujanyakj
If we using the SWIM functionality of the DNAC , would 80 port should be allowed by  to cisco.com, cant we fetch the image using 443 port
Also , as per the below link , with ISE below communication to be opened, is it encrypted /secured communication?
UDP 1645 or 1812
RADIUS
Needed only if you are using external authentication with a RADIUS server.
Port must be open only if an external RADIUS server is used to authenticate user login to Cisco DNA Center.
TCP 5222, 8910
Cisco ISE
Cisco DNA Center uses Cisco ISE XMP for PxGrid.
Port must be open for Cisco ISE.
TCP 9060
Cisco ISE
Cisco DNA Center uses Cisco ISE ERS API traffic.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/hardening_guide/b_dnac_security_best_practices_guide.html
Torbjørn
It specifies that port 80 is _one of the ways_ the DNAC is able to fetch images for SWIM. It is also be able to use port 443 for this. For reference, see the SWIM URLs listed in this install & upgrade guide: https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-3/install_guide/2ndgen/b_cisco_dna_center_install_guide_2_3_3_2ndGen/m_plan_deployment_2_3_3_2ndgen.html
For the remaining questions: RADIUS does not encrypt the entire payload, but it encrypts the credentials using a shared secret. ISE PxGrid XMP and ERS uses TLS for traffic encryption.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
